Best SBC cam and crank bearings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2004, 01:08 PM
Sagacious's Avatar
Do you feel like we do?
who makes the absolute best cam and crankshaft race bearings? i want them to last the absolute longest. i had a pushrod break and some metal floated around in the engine, everything else is fine but the cam and crank bearings are a little worn. i could use them over again but i bought a new engine and thats what i intend to have, so im not doing anything half-***. so im going to do it even better this time. thanks for the help...
clevite77 any good?
Old 10-07-2004, 01:37 PM
DoubleVision's Avatar
Clevite makes excellant bearings, as are the GM Morraine bearings, however, it doesn`t matter which brand of bearings you use, if any material gets in the engine they wear, and if they can`t they inbed the object. In most cases in fresh rebuilt engine wear I`ve seen was from lack of cleaning it, hone dust sticks in the bore real good and you have to scrub it hard to get it all out, lack of lube from start up or start up with revs also will make them show premature wear, lack of immediate oil change after cam break in and etc.
Old 10-07-2004, 01:52 PM
firestone's Avatar
http://teamrfc.gospelcom.net
As far as the bearings go, I agree with the above. As far as the cam and crank go, I am not sure if the "best" is what you really want. I run a LAE billet steel crank in my car but it cost $3000. I would go with something like Eagle. A 4340 forged Eagle crank will handle alot of power. If you are interested in a LAE crank, there is a site below that sells them. As far as cams go, I have always been pleased with Comp Cams.
LAE
http://www.bennettracing.com/products/crankshafts.html
here is a place to look at eagle cranks
http://www.jegs.com/cgi-bin/ncommerc...99&prmenbr=361
Adam
