Best sealant for threaded connections? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2008, 10:36 PM
406 bug's Avatar
9.82 @ 139mph
Just wondering what you guys have had the best luck with when sealing the following threaded connections: Water, oil, fuel and brake fittings.
Thanks, Ken
Old 09-27-2008, 06:29 AM
Permatex Aviation Form-A-Gasket, P/N 80019. You should 't need/use anything on a brake fitting.
Old 09-27-2008, 08:25 AM
OHD's Avatar
OHD OHD is offline
Permatex "the right stuff" Marine grade will seal them all. If you need brake line sealant remake the line "flare" or replace the block, too much pressure.
Old 09-27-2008, 12:10 PM
406 bug's Avatar
9.82 @ 139mph
Regarding the brake fittings, its the npt fittings (for instance on the calipers).
Wilwood uses some sort of redish looking stuff.
Thanks for the help. Ken
Old 09-27-2008, 12:58 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
On brake fittings, do not use any kind of telflon tape or paste. even the most careful application can let chunks of teflon pull off and make their way into the lines. The last thing you need is a big chunk of teflon clogging up something at the wrong time.
Most of the smaller NPT fittings like a brake line would use can be sealed without anything. Wilwood puts that red stuff on as a way to make it fool proof. Its an elastomer stuff that won't tear or leak or be dissolved by brake fluid. You would have to contact them for what it is.
As for the others, its depends on the fitting. For any NPT fitting you can use teflon (I prefer the paste) on water fittings. You can use it on fuel fittings as well, but make sure you have access to both sides of the fitting so you can clean out any that squished out before letting the gasoline do it for you.
Flare fittings require that you use nothing. The threads don't seal anything, the threads merely pull the flared sections together. putting sealant on the threads just increases the risk of stripping the threads Just use a little drop of oil.
Old 09-27-2008, 01:16 PM
OHD's Avatar
OHD OHD is offline
I have always used line wrenches, but some guys are stronger than me...
Old 09-27-2008, 03:29 PM
T-bucket23's Avatar
Wiki Edits: 26
It may be a lubricant to keep threads from gauling. No sealant on brakes. Double flares will never leak if done properly.
Chet
Old 09-27-2008, 10:31 PM
+1
Question on correct way to apply sealant to bolts v8hed Engine 3 07-27-2008 06:46 PM
Aviation Form-A-Gasket Sealant for headbolt threads? j.d.brown.042964 Engine 10 06-21-2008 12:49 PM
Ford fuel pump connections? 1953 Homer Engine 3 02-05-2008 10:18 AM
What is it? - sealant on fuel tank sabino56 Engine 1 09-11-2005 11:04 AM
rear fender sealant '67 C-10 Walker Body - Exterior 1 01-26-2004 12:36 AM
