Best sealer for fuel panels? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2010, 09:07 AM
Working with setup like so...
Running dual intank pumps.
Fuel is leaking out the top of the panel. I'd like to use some sort of sealer as well as the factory gasket. I had to "massage" the factory fuel pump opening to get my 2 larger fuel pumps installed.
Looks like they were using some sort of blue sealer here? Not sure if it's e-85 compatible.
Thanks all!
Old 09-30-2010, 11:37 PM
With 70 plus views and NO ANSWERS ...
I am going to bring this back to the top.
I myself have no answer ... either
Old 10-01-2010, 05:47 AM
Haha, Yea no kidding!
You guys usually have the answer to all my issues! Maybe I can help out someone for once!
So I ended up using a permatex product called "The right stuff" few local guys use it and so far it's been holding up to e85 for roughly a year now.
So far so good!
"Basics of Basics" Moisture shields behind trim panels. MARTINSR Body - Exterior 11 07-17-2009 11:30 PM
"Basics of Basics" Moisture shields behind trim panels. MARTINSR Interior 1 07-16-2009 01:46 PM
Problems with SPI white sealer?? 35prog Body - Exterior 3 04-19-2008 03:03 PM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 12:36 AM
Door panels stangrodder Interior 4 12-22-2004 10:26 PM
