Best seam sealer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2009, 09:06 PM
Best seam sealer?
What would be the best seam sealer for my quarter panel repair? I also need it to be paintable too. Thanks.
Old 08-17-2009, 09:01 AM
Last journal entry: 50 Ply wagon
Most body shop supply places sell seam sealer that is paintable. If you don't have one near by, check out Eastwood.
Old 08-17-2009, 11:27 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I would use a two part Seam Sealer-I've used the 3m brand-it is paintalbe, doesn't shrink and will last a long time-look here:
http://solutions.3m.com/wps/portal/3...gl7S9CZ5Q1J6bl
Old 08-17-2009, 02:01 PM
I have used "mechanica" brand paintable seam sealer in the cheese wiz cans and it worked extremely well for me.
I also used 3M on the last car I did and it wasnt nearly as nice as the mechanica brand stuff I used. It was more difficult to lay a nice bead and wasnt as neat when I was finished. Both accepted paint just fine.
I have also used HV-350 Adhesive from Valco Cincinnati Consumer Products. Its a paintable adhesive sealant that can stretch up to 600% its own length without failing and its got incredible grip. It takes longer to cure than traditional seam sealers though. It can be found at www.*******.com
Last edited by Jon; 08-17-2009 at 02:19 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 08-17-2009, 02:24 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
See the "Seam sealers" section of our massive wiki rust article: Seam sealers.
I would also check out this article by MARTINSR: "Basics of Basics" Seam Sealers.
remove all the old seam sealer? dmcphee07Si Body - Exterior 5 07-26-2009 07:30 PM
What SEM seam sealer? glhx Body - Exterior 3 05-03-2009 08:37 PM
body filler vs. seam sealer daves66valiant Body - Exterior 1 04-16-2009 10:00 PM
Seam Sealer or ? jcclark Body - Exterior 4 05-06-2006 06:05 AM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 01:36 AM
