Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best Shop Floor Paint
Old 06-02-2009, 08:57 AM
Beenaway2long's Avatar
Beenaway2long Beenaway2long is offline
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Whether you use high dollar epoxy, or low dollar Home Depot, NOTHING will stick if you have moisture issues.
Be sure to tape a piece of foil to the slab for a couple days. Lift it off. If its damp under the foil, dont waste your time on coatings. They will lift right off.
