Thread Tools Search this Thread share on Facebook
  #1
Old 03-25-2009, 07:24 AM
345 desoto's Avatar
345 desoto 345 desoto is offline
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Best Shorty Header Paint
Other than Jet Hot type coatings, what is the best header paint to use on a set of Shorty headers...and would sand blasting help?...
Register now (free) or login to remove ads
Old 03-25-2009, 08:03 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
I have never found any "rattle can" header paint worth a flip, none seem to last. My current set of headers were ceramic coated silver and still look new I installed them 2 years ago.
Vince
Old 03-25-2009, 12:01 PM
oldbogie oldbogie is offline
I always say rust is the natural color of headers. Factory applied industrial coatings like ceramics or chrome are pretty good, lasting several years. I've never seen rattle can painting hold up. The temperatures involved are simply too high and last for too long for high temp paints to survive for very long.
However, if you're going to do it, removing the rust is an important step. Rust really can't be painted over successfully because it always flakes or peels off the base metal. So the process of doing that takes whatever coating is on the rust with it.
Bogie
Old 03-25-2009, 03:00 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
I was looking on another forum pertaining to this subject and ran across this product....
http://www.techlinecoatings.com/Exhaust.htm#blacksatin
4 oz $20
12 oz $50
32 oz $125
Old 03-25-2009, 09:08 PM
sam_bo3 sam_bo3 is offline
what about wood stove/ fireplace paint? I got flat black and while it doesn't get hot my rally rim still look good. It holds on well. I may try it on my headers just too see. 6 bucks a can is cheap enough. It painted 4 rims and still have some left over from 6 years ago.
Old 03-25-2009, 09:26 PM
crownver crownver is offline
I was in a store the other day and mixed in with the high heat rattle can paint rated to 650 deg. there were a few colours with a 1500 deg. rating. How hot do headers get?
Old 03-26-2009, 08:17 PM
matt167 matt167 is offline
Wiki Edits: 31
they can get up to 2000* or so if the engine is running lean.. 12-1,500* usually
Old 03-27-2009, 09:06 AM
GenYnNC GenYnNC is offline
eastwood sells a pint or so of 'iron grey' with cermaic particles in the paints... best stuff I've tried... it does actually stay on and I've tried it on stock manifolds and tubular headers- if it starts to flake off or lock bad, simply brush a small bit on the rusty place.
Old 03-27-2009, 02:27 PM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
I used some Dupli-Color Ceramic 1200º paint on my shorty headers. Aluminum color.
http://store.summitracing.com/partd...15&autoview=sku
One can put down 3 wet coats. Although I haven't got to the point of putting the paint to the test. I did however sandblast off all the black protective paint the factory put on (recommended by Dup). They also recommend you bake the coating at 300º for about 20 min or so before installing.
Old 03-27-2009, 11:52 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Black fireplace coating works pretty good, turns grey at the high temp zones. Easy to reapply too.
Old 03-28-2009, 10:40 AM
Studebaker Studebaker is offline
I have good luck with high temp VHT brand. Found it at Autozone. The key is to clean or sand blast the headers first and wipe them with a evaporating grease cleaner. Cleaner the better. I always use a torch to heat metal parts before painting, removes an residue, oils, etc. I then let the metal cool slightly so that it's warm and then paint. I have had really good results. I have a set of shorty headers that still look good after 10 years. Much like painting anything else, the prep is very important.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Best Shorty Header Paint"
ThreadThread StarterForumRepliesLast Post
Paint question for the expertsKevin45Body - Exterior3402-23-2009 05:03 PM
wax and grease removeradrock430Body - Exterior1407-30-2006 12:18 PM
Cost of paint Job - complete do it your self job at homeWarrantBody - Exterior7407-13-2006 09:31 PM
This is interesting. Temporary peel off paint.kenseth17Body - Exterior508-11-2005 09:41 PM
Change colour high temp header / turbo paint?SyclonedBody - Exterior108-03-2003 09:08 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
