Since you have a PPG dealer nearby I would suggest using PPG, but not Omni. Omni is their low end line and although it's a good paint (I used it on my 53 pickup) it requires more coats because it has less pigment and fewer solids than PPG's better lines.
In the long run it won't cost much more to use one of their better paint lines such as Delta, Deltron, or Global DG. |
Glasurit. Used PPG for years till I got a really finicky customer. He popped for a Glasurit redo and 10 years later still looks like new. No hazing or polishing micro scratches.
Might be doing a '55 Chrysler limo soon and it'll be Glasso for sure |
why single stage? the base clears are way more forgiving and you can cut and buff a clear coat pretty easy where cutting and buffing a single stage is scary at best left to the pros.
what the thought behind single stage? jeff |
Go with the BC/CC
theres not enough pigment in omni to do a black car. when you sand and buff you'll end up with a colored haze. tried it once. never again. my favorite was centari enamel with the urethane glamor kit. i have one 11 years old and still looks great. stick with top shelf paint. bargain brand second lines are a disaster waiting to happen.
dont believe that for a minute but if you still want to go single stage then i have to agree on glasurit. their "22" line wich is acrylic urethane is really awesome. sprays smooth and the gloss is awesome even without sand and polishing. i would still go bb/cc though. any way you do it if your going to wetsand and buff the clear you;ll get the deepest black but its also really in the quality of the basecoat. some blacks look more brown than others. hok is real black but spi is the blackest i've seen. |
There are definately pros and cons to both (SS vs. BC/CC). Concept singlestage black is definately some nice stuff. Another option is to mix clear in with the singlestage black 50/50 on the last two coats for more depth- I've done comparisons and it does add depth and also darkens the color. Bob
I never did the single stage mixed with clear.. m guessing u have to use a clear ment for that or does any clear work?
Also i just used the spi black and its even deeper then hok's which is black black. |
A bit off-topic, but I do believe SS black can and does look different than BC-CC black, because I have seen it myself, especially after polishing. I haven't heard any official explanation for this, but my theory is easy to understand: If you scratch clear, it looks white. If you scratch black SS, it usually looks dark brownish. Now, if you have buffed a vehicle, no matter what your eye tells you, it is full of microscopic scratches. In clear, these scratches will reflect a full spectrum of light, while in single stage, a more limited spectrum will be reflected, causing the two to have a different appearence, the SS being darker, or more true to its own color.
An easy way to look at this is black single stage is mixed in the clear already (so to speak) So I will let you all argue witch is the best but will say all things being equal the black basecoat will be blacker. Think about it. Yes it looks different as there are two type of glosses, shinny and depth. Singlestage has gloss but no depth. That is why an inside show a single stage would never win. The lights would kill it. BWK |
I've done some nice SS black jobs with clear mixed in 50/50 on the last two coats and they are deeper and darker than plain SS, but yeah BC/CC is even better if the final sanding and buffing is done correctly. You can do your own test panels and verify but I've seen it for myself. The only drawback to BC/CC is that your surface scratches show much more than in a SS, but if the clear is perfect it does have a deeper and darker look.
Do a testpanel and see for yourself, apply two coats of plain SS, then come back the next day and tape a section off for two applications of SS mixed 50/50 with clear, then on the remaining third of the panel do a straight clear. If you really want to guage the differences use a black that has a brown shade to it. |
| Single stage and duel stage air compressor? | DeathByGreaser | Body - Exterior | 24 | 10-19-2005 06:33 PM |
| single stage or used 2 stage? | zimaad | Garage - Tools | 9 | 08-04-2005 08:19 PM |
| Clearing Cured Single Stage | Riverman | Body - Exterior | 7 | 07-14-2005 05:39 AM |
| Sanding single stage? | Project87c10 | Body - Exterior | 6 | 11-05-2004 12:44 PM |
| bc/cc over single stage? | Lay'nFrame | Body - Exterior | 1 | 06-04-2003 01:56 PM |
