Best Spark Plug Wires?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2002, 09:34 PM
Post Best Spark Plug Wires??
I have discovered some bad plug wires on my 1969 350 Chevy with stock exhaust manifolds. I drive the car on the street with no racing, but I would like a quality wire that will last a long time and still permit me to play the radio without static. I am going to replace the wires but there are so many to choose from, I don't know which brand is best for the money. Can anyone tell me about their experience with plug wires? Good and bad??
Old 09-14-2002, 06:15 AM
dollybud's Avatar
Cool
Personally speaking I like Taylor. I've had no problems with them even with a few pretty close to the headers. Use spiral core, magnetic suppression, 8 mm wires .
Tom
Old 09-14-2002, 08:34 AM
dmorris1200's Avatar
doesn't play well with others
Post
I'm using 8mm Accel Super Stock suppression core custom fit wires. I like the look, they work great, no radio noise, and they're pre-cut to fit your application. You can see them on my engine in my photo album for this site. If you don't have a local dealer I think you can get them online at <a href="http://www.summitracing.com" target="_blank">www.summitracing.com</a> .
[ September 14, 2002: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 09-23-2005, 05:30 AM
'57 Fairlane
But what to think about wires with solid copper inside? I believe that they have no resistance at all and this is really good point.
But do they cause any unseen problems? Radio interferences?
Old 09-23-2005, 09:16 AM
Two wire sets that we have had excellent luck with on the dyno are Taylor 409's and MSD 8.5's. Both have excellent coverings that can withstand high heat conditions without shorting. Plug boot size though on both sets can be a problem though with some manifold setups that are very close to the plugs so routing is very important.
Old 09-23-2005, 07:02 PM
Well, first off they are illegal on street driven cars, and have been since 1955, by FCC regulation. In the second place, they will burn up most electronic ignitions in short order, by RFI interference. And third, with the coils we use today, even with point ignitions, they aren't really effective.
Old 09-23-2005, 08:44 PM
347mustang's Avatar
a illegal plug wire...lol..thats a good one
Old 09-23-2005, 09:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Also, the pulsing current through them sets up magnetic fields, vibrates the wire strands and they fail internally. All-in-all not good for the street. For my money any good name brand wire is fine (Accel, Taylor, MSD, etc.), I prefer Accel 'cause I love yellow! The absolute best of both worlds - max current and max radio suppression - is offered by the spiral wrapped core. Those have a fiberglass carbon core like suppressor wires for maximum tensile strength that is wrapped with fine stainless steel strand that has little resistance. Here is one example but they all make them.
Old 09-24-2005, 12:34 AM
Jmark's Avatar
Do any of the good wires have the little button on the cap end? The button goes into the round plastic wire holder that snaps onto the cap.
Old 09-24-2005, 04:10 AM
GoneNova/406's Avatar
msd tells you not to use them with their electronics.
Old 09-24-2005, 10:00 AM
Taylors
For the money, it is hard to beat the Taylors.
Arn
Old 09-24-2005, 11:23 AM
Wiki Edits: 21
I have been using my spiral wrapped wires w/ Chrysler electronic ignition and MSD5 box for 6 or 7 years and everything has worked great. Just wish the rest of the car were so trouble free!!
Old 09-24-2005, 12:38 PM
PrimeMover's Avatar
Sittin' on top of the world...
I chose MSD Heli-Core wires mainly because the blue matched up with my motor really well and the dist. end boots fit real good under the Accel HEI Super Coil top hat. It sounds like Jmark is still running a stock GM HEI distributor wire retainer setup. Most high perfomance wire sets dont come with mushroom heads on the distributor end boot because most all of the aftermarket stuff no longer uses 'em.
I've had the MSD wires on the 53 for five years now, and haven't had a lick of trouble with them. Even as close as they are to the headers, they still haven't started getting brittle yet or broke down under the heat.
I started out with a spendy cut-to-fit set of 12MM wires that came with a crimper to do the the terminal ends with. After a half a tube of dielectric grease and cussing up a storm trying to get the angle boots slid down over wires I went with the taylor-made set of MSD's.
Old 09-25-2005, 01:06 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
technically he's correct..... creates illegal radio/tv interference for others.... but if you're not in CA or NY...... who will can your a--s?
Old 09-25-2005, 01:12 AM
xntrik's Avatar
Based on my experience with several brands...... spiral core wires wipe out your weaker signal AM radio listening, and occasionally some FM too.
Accel yellow carbon core wires will cross fire from something like a DUI coil/distributor.
Carbon core wires are the best if you have any radio concerns. If you have a hot ignition, forget the fancy radio stuff, it ain't gonna happen.
