Best spark plugs for MPG - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2008, 09:47 PM
I just rebuit my Chevy 4.3 , 93 C1500 Truck so it all new now. What would be the best spark plugs to get for best gas mileage also what about the wires.
I have 8mm on there now are they good ? and should I keep the timing at spec ? Gas price are high I need to save all I can. Thanks
Old 05-10-2008, 10:07 PM
Jmark's Avatar
Stick with the factory recommendations and specs and keep your foot out of it! LOL
Mark
Old 05-10-2008, 10:16 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Also replace your fuel filter and air filter frequently, and check your tire pressures weekly.
Old 05-10-2008, 10:51 PM
SSedan64's Avatar
Has anyone had better MPG results with Splitfire or E3 plugs? I've heard splitfire are good for HP but definetly not with Nitrous Ox though. Instant Glowplug.
Old 05-10-2008, 11:31 PM
327NUT's Avatar
A L O N G time ago I tried some Splitfires.......nothing different at all. Then I read some magazine tests on plugs and they found no real improvement. I think its all a bunch of snake oil and marketing hype anyway.
Old 05-10-2008, 11:45 PM
My 2 cents worth
Wiki Edits: 3
Don't you think that, if they worked as marketed, the vehicle manufacturers(who are being pressured by the EPA for mileage and economy) would install them and recommend them?
Just my 2 cents worth.
Old 05-11-2008, 01:06 AM
techinspector1's Avatar
Wiki Edits: 326
Posted by carsavvycook:
"Don't you think that, if they worked as marketed, the vehicle manufacturers(who are being pressured by the EPA for mileage and economy) would install them and recommend them?"
BINGO
Old 05-11-2008, 02:21 AM
JeffB's Avatar
Spark plugs
Since you are running a GM try the AC Rapidfires,I used them in several cars and picked up a mileage gain and smoother running too,but plugs are like women, we all like something different
Old 05-11-2008, 09:05 AM
DENCOUCH's Avatar
Yep, and have you noticed how much their heat ranges vary? Both too cold and too hot will give you problems at sometime n your life
Old 05-11-2008, 10:02 AM
Banned
I know they're more costly and you will most likely never recoup your costs through savings at the pump, but Iridium plugs are really amazing. They're not really snake oil either but they do cost $15-$25 a piece which is expensive for a V8 plug change- even if its a 4.3L six its still not cheap. Probably the best hting for milage is limiting parasitic loss and going easy on the pedal.
Old 05-11-2008, 11:38 AM
NO spark plug is going to improve our gas millage unless something is wrong with the ones your pulling. Unburnt fuel only accounts for 1-2% so even if you did improve combustion 1% you would be talking about .1 - .2 mpg
Jordon
Old 05-11-2008, 01:35 PM
Haulin327's Avatar
i HAPPEN TO LIKE NGK SINGLE PLAT-
They have extended nose and small electrode,a very nicley designed plug,like a iridium but cheaper at about $2.25 or so...
I say NGK or Denso
Old 05-11-2008, 09:14 PM
Thanks guy alot of good info
Old 05-11-2008, 09:22 PM
kleen56's Avatar
I know most of you won't care for this mpg improver, but I pulled my 3.50 gears out of the rearend and replaced them with 2.75's. I gained about 4 miles per gallon changing them out. It also keeps me from putting my foot into it around town. Just a suggestion.
Old 05-12-2008, 12:48 AM
anything but Bosch--i like their tools, but the spark plugs are junk
Expensive Spark Plugs Worth It? Kampr Engine 19 12-10-2007 01:02 AM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 01:05 AM
motor wont start spark plugs have oil on them 54chevy22 Engine 3 09-11-2006 07:59 AM
motor wont start spark plugs have oil on them 54chevy22 Engine 13 08-10-2006 10:28 AM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 06:51 PM
