best spot for a ground? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2011, 07:36 PM
hey how are you, i was wounding how many grounds and where to put them on an engine. At the moment i have one ground cable from the battery to my aluminum head. and one ground from the battery to the fender. (its a 86 Monte ss By the way, 357 sb)
Old 04-08-2011, 08:03 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
A framed car gets a line from the negative battery to the motor, motor to frame and frame to body. A unibody car gets a line from the negative battery to the motor and motor to body.
I'll tell you how I do it, you do it as you wish. I make up my own lines from #4 battery cable cut to length, then sweat on copper lugs and cover them with heat shrink.
Battery negative to motor: There will almost always be a threaded hole somewhere on the block or head. If not, use a bolt that holds something else and is handy. Run a finishing tap down to the bottom of the hole and blow out the chips and other crud in the hole by spraying carb cleaner into the hole with the little red straw that comes with the can. Watch your eyes and do not breathe the vapor. Now, use a file or your pocket knife or other suitable tool to scrape off all crud, paint, rust, etc. from around the hole. You want the lug laying against bare metal when you tighten the bolt down. Cover the entire connection with clear silicone so that no moisture can get into it.
Motor to frame: Same way, but with a plain lug on each end of the cable. If there is not hole in the frame to use that's convenient, drill the proper size hole for a self-threading bolt. Make sure there are no fluid or electrical lines running inside the framerail that would be breached by drilling a hole. You don't have to push the drill bit all the way in, just stop when you feel the bit clear the metal on the other side of the rail. Use a file or knife or sandpaper to make a large, clean, bare spot of shiny metal to attach your lug to, then seal it as above.
Motor to body or frame to body: Find a place on the firewall where there is already a hole that you will have access to from the outside and from the inside of the car. If there is not one available, then look around for a good spot. You will want a spot on the inside where you can get to it with a socket or wrench to hold a bolt head. We're going to use a bolt and nut and maybe a couple of washers for this one. On the motor side, clean off an area down to bare, shiny metal where the lug will sit so that the lug will not be sitting on any painted part of the firewall. Run the bolt into the hole from inside the car and have a buddy attach the ground cable/washer/nut and tighten it while you hold the bolt head from inside. Once tightened, cover the connection thoroughly on the inside and the outside with clear silicone.
Old 04-08-2011, 08:09 PM
ok cool thank you, i currently have a 8g wire from the battery to the fender, should i remove that or just keep it?
Old 04-08-2011, 08:25 PM
Senior Curmudgeon
Wiki Edits: 326
I don't think it's possible to have too many grounds.
Old 04-08-2011, 08:27 PM
haha ok cool please check out my tdc? post i recently posted today and help me with that if you can please
Old 04-08-2011, 08:31 PM
Senior Curmudgeon
Wiki Edits: 326
already did....
Old 04-08-2011, 11:32 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
yep, you can't have too many grounds
For a good solid ground, here is what I do. I buy a side post battery converter - one of those posts that is supposed to screw into a side post battery and has the big lead post on it. Drill and tap the frame beside the engine for that post. Then put one of these from an accessory bolt to the frame. Dead reliable.
Old 04-09-2011, 12:03 AM
Link please!
Old 04-09-2011, 01:40 AM
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by veltboy314
Link please!
http://www.grainger.com/Grainger/GRO...-Braided-2FFY6
http://www.amazon.com/Mallory-28135-.../dp/B000COMR00
Old 04-09-2011, 05:46 AM
bentwings's Avatar
bentwings
Since my ride is 'plastic' grounds are number one priority. I have battery to frame ground right at the battery. A big one like the picture.
Then the block and aluminum heads are both grounded together, the blower manifold and block are grounded together. Then there is a big ground strap from the block to the frame. All grounds are ground clean then bolted down.
I have 4 large ground terminal blocks in strategic locations on the body. These have 10 ga wire directly to the frame, again on a fresh clean spot. I service all frame connections in the early spring.
The ignition MSD has it's own hot side and ground wires directly to the battery except for the switch control.
You get bit by the 'ground syndrome' only once on these cars.
BTW, aluminum gets surface oxidation which begins immediately after cleaning and gets thicker with age. This is an excellent insulator. So is anodizing which is colored oxidation. I would not use a main ground on aluminum. This is why we work so hard to clean aluminum right before TIG welding....get rid of the oxidation as much as possible.
Ground to the block.
Old 04-10-2011, 08:44 PM
curtis73's Avatar
Wiki Edits: 16
Link please!
I found all of my stuff at Auto Zone. Look for one of these: its an adapter to change a side post battery to a top-post style cable. Just drill and tap the frame and screw it in.
Old 04-10-2011, 09:11 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
NAPA Balkamp #770-6119
These ground straps are especially suited for grounding things like hoods, trunk lids, tailgates / liftgates ... etc. Anything with hinges.
You'll also see a couple more between the frame and my pickup box and the rad support. Rubber mounts are poor conductors as well.
Old 04-11-2011, 02:32 AM
Senior Curmudgeon
Wiki Edits: 326
That is very slick.
Old 04-11-2011, 06:26 AM
Irelands child's Avatar
Even for my after market steel car I have "several" dedicated grounds. One direct from the battery to the engine, then another from the engine to the chassis (these are like the woven ground cables shown above) then a third from the engine to the body and another (fourth) to the fuse panel which is for the gauges. Then there is the ground from the gas sender to the chassis and another for the MSD. The lights all have separate grounds to the chassis - tail, cowl and head lights. The trunk lift has a separate ground to the body. Probably more. The heavier gauge they are along with good bolts the better the connection/ground (I used some brass bolts plus some anti corrosion dielectric grease along with star lock washers too)
Dave W
Old 04-11-2011, 11:48 AM
35terraplane's Avatar
B est spot for ground
What everyone has said is good advice, except I would not try to ground to Aluminum, as Aluminum is not a very good conductor of electricity, therefore it makes a poor ground, it will work, but steel is better by far.
Bob
6v positive ground to 12v negitive ground darksidecustoms Electrical 3 07-20-2009 08:29 PM
dry spot benchracer1 Body - Exterior 3 01-24-2009 09:54 AM
spot weld duallybuster Body - Exterior 6 12-02-2005 03:53 AM
Run in Clear at a bad spot.. what to do?? Z-Money Pit Body - Exterior 6 06-21-2005 01:53 PM
Spot the mistake!! crazygutgut Hotrodders' Lounge 11 05-24-2005 07:54 PM
