Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best spot weld drill?
Old 01-09-2010, 01:03 AM
Twisted Minis's Avatar
Twisted Minis Twisted Minis is offline
A different breed
Last journal entry: New Truck
I use a Blair spotweld cutter. Very nice quality, unique design. You have to center punch the spot weld for it to center itself successfully. I have about $50 into mine, but I have about every size head for it you would need to take a car apart. If you just need one size the cost is about $25 if I remember right. The main cost is the piece that is spring loaded and holds the bits. I use mine in a shop setting, and they are still going, probably cut almost 1000 spot welds with it so far.
