best steering column for 29 Ford street rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2001, 02:34 PM
Talking best steering column for 29 Ford street rod
I am trying to piece together a 29 ford street rod. I need a steering column and box for it and am on a budget. I have looked at rodder magazines with new columns for sale specifically for what I am doing but would like to look at other alternatives. Would a column from a late model vehicle work with little or no changes to be made. Any suggestions on what you or others have tried would be welcomed. Thanks. Happy Thanksgiving!nullnull pikalpha@pell.net
Old 11-27-2001, 06:43 AM
Post
I am presently usinga mid eighty`s Camaro steerin column with a late 60`s mustang steering box coupled by a u-joint from Borgeson made for just the application very inexpensive set up
Old 11-27-2001, 05:20 PM
New Member
Post
pikalpha I am working on a 26 Ford T Model and using a mid 70's Trans Am colum along with a 66 Mustang box with a u-joint from Speedway Motors.Keep asking questions and like me someone will turn you on to a good combination for your project.
Old 11-27-2001, 05:40 PM
New Member
Post
pikalpha Like you,I too am on a budget and my setup only run me around $75.00. Look on eBay you can find some good deals there.
Old 11-28-2001, 07:32 AM
Post
Hi, I used a mid seventies saginaw 525 steering box non power from a Chevy but most of the GM mid size cars had them. I found a 66 chevy with a plain column in a local junk yard and the total came to $65 dollars for this cross steering set up. The only other parts are U-joints and steering shaft(not cheap). This went into my 31 Ford coupe. Both the Mustang and Saginaw will work the Saginaw may be eisier to find .good luck
Old 11-28-2001, 10:54 AM
Post
I am building a 1928 Model A 2dr sedan, I am using a Steering collum from a 1970's chevy van. I went to 3 Rod builders around my area and they suggested the collum, also using a Chevy Vega gear box.
