Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best tilt column
Old 01-14-2008, 07:14 AM
Deuce Deuce is offline
It actually depends on the vehicle you are trying to install the column in ... I have found, that for me anyway, a Chevrolet/GMC van tilt works out best. I have put them in Model A's , 32 Fords and 33 - 34 Fords. I even used one in my brothers 40 Ford coupe.
Here is one in my 32 Ford 3W project. The early to - late 70's models are the ones I prefer to use. No key in the column, has the P R N D L2 L1 indicator on the column and a neutral start switch. Uses a standard Chevrolet steering wheel so lots of choices there ...
Easy to hook up on the firewall side with lots of joint combinations available from the after market.
