Best Timing setting SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 04:54 PM
Dave E Shank's Avatar
Post Best Timing setting SBC?
I am running pre electronic 350 Chevy, with mild cam, quadrajet for street use only. What seems to be best setting using timimg light?? I am set at 12 degree before and appears to be okay,a little extra cranking when hot but no ping.. Any thoughts!! DAVE Shank
Old 12-17-2002, 05:40 PM
DoubleVision's Avatar
Post
12 degree`s is the norm, with 36 to 38 in by 3000 RPM, you can slow down to 10 if need be. if you still run into hot start problems, I`d check the grounds. make sure you have the best grounds possible.
Old 12-17-2002, 05:43 PM
Post
WITH INFO SUPPLIED 12 IS GOOD AND 22 BY 3000 RPM I DONT THINK A LITTLE OVER STOCK WILL HANDLE 36 TO 38 DEGREES.
[ December 17, 2002: Message edited by: rooster ]</p>
Old 12-17-2002, 06:13 PM
bullheimer's Avatar
NEVER use credit cards!
Thumbs up
The Force, Luke. Use the Force. :p
