Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best tire PSI for street radial tires?
Old 07-18-2010, 06:24 AM
Ford Junkie's Avatar
Ford Junkie Ford Junkie is offline
No substitute for cubic inches
Same test for traction. Unlessss your doing a burnout before hand if so then you'll have to drop the pressure some as it will increase with heat from the burn out.
You don't want hte rolled edge sitting on the pavement very much maybe 1/4" or so.
