Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best tire rim size / Road & 1/4m drag ?
Old 02-26-2005, 12:39 AM
draven's Avatar
draven draven is offline
Low on turn-signal fluid.
Originally Posted by x007
i will take a look...
Its hard to be sure of the size, since i will most likely buy it online i
want to avoid any error.
ps: does the Et street have to be bolted on rim ?
Et street require tube right ?
With that much horsepower I would recommend tire screws. The ET streets can be ran without tubes, I ran mine without them and they leaked a little air now and then, but with that much horsepower I would also recommend tubes as they are supposed to have tubes. I recently switched to the MT ET Street Radial which is tubeless and lasts a LOT longer, and they hooked the same for me, I really like them.
