Like most projects, whatever tool works the best at the time. I like the 4" cutoff wheels on a hand held grinder. If I'm seperating a spot welded seam, drill out the spot weld on the piece your removing and then air chisel it off. If the layer your removing is really rusted, I don;t even bother cutting at the spot welds, the air chisel will pound it right off. I've even used a cutting torch to burn off the top layer of a seam.
Just make sure you protect the glass if you use the grinder to cut, the sparks will imbed in the glass and you'll have a mess. |
Ideal tool for cutting out a floor is a plasma cutter, but not everyone can afford that. The cutoff wheel is probably your best bet. I use a good set of shears too.
Ontario Rodders |
Yea I would love to use a plasma but the funds are not there yet! Some day after the wife has a few kids I'll be sure to get one. I hope anyway
Arrowhead thanks for the tip about the glass. Thanks Mike from MI |
One of those air body saws work well..they look like a mini sawzall..I use mine quite a bit...A lot less than a plasma cutter..Get a good one tho..
Sam
| Adjustment tool for TPS screw | sabino56 | Engine | 1 | 11-27-2005 06:11 PM |
| Bought a Cutoff & Talk Hf Tool policy | 1Fast65Elky | Garage - Tools | 22 | 09-04-2005 11:46 PM |
| push rod clearance tool | lanierledford | Engine | 1 | 07-04-2005 08:32 PM |
| New Scan Tool user | 36scsc | Electrical | 3 | 01-29-2005 07:35 PM |
| front end popping | maddmaxx | Suspension - Brakes - Steering | 4 | 11-15-2003 08:24 PM |
