Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best Tools for the Job
  #18 (permalink)
Old 12-25-2012, 10:46 AM
MARTINSR MARTINSR is online now
I haven't read every word of this thread but wanted to throw out there that the most important part to using any tool is that it is the correct tool as in the correct size as well. I have seen so many phillips screws and drivers destroyed because the guy was trying to remove a screw that required a larger or smaller screw driver.
You need to clean out the screw of junk, you need to slip the driver into the hole and wiggle it a little making sure it is the right size that it is filling the hole in the screw properly.
