best trans cooler for 50 bucks - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2005, 03:12 PM
I have a 400-450 hp 357sbc with a TH350 tranny and 3,000 jegs converter. I was wondering what the best trans cooler kit for this application is, that I can get for around 50bucks. I look in jeg's and there are a lot for 50 or a little less, but I'm not sure what to get. I was thinking the perma cool thinline cooler kit, I think it's a 24,000gvw.
Old 05-13-2005, 03:37 PM
I like the stacked plate type coolers better then the tube & fin type. B&M is one brand that sells stacked plate coolers. Get the highest GVWR you have money for.
Old 05-14-2005, 06:25 PM
Go to your local U-haul depot, they have a good selection of Trans coolers.
Or, just find a pickup with one in a boneyard.
Old 05-15-2005, 10:08 PM
Try O'Reilly's
I just got a stacked plate type name brand cooler
(Hayden I think? - good memory here ;-( )
for about that, had the hose & connections with it,
was their 2nd highest rated cooler - something like
7 or 8k lbs rating.
They're also online.
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
air conditioner rad for trans cooler? cboy Transmission - Rearend 15 01-17-2005 02:53 PM
????about putting a trans cooler on??? Robbie Transmission - Rearend 1 04-17-2004 08:53 PM
Trans cooler hook-up???'s juveteach Transmission - Rearend 9 09-15-2003 03:23 PM
