Best Transmission And Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2005, 10:15 AM
What Would Be The Best 4 Speed Manual You Could Put In A 67 Camaro With 327. The Most Dependable For Street And Cheap. Also What Would Be The Best Rear End Gears. For Takeoff And Speed. Is Low Gears Better Than High Gears.?
Old 05-24-2005, 10:48 AM
302 Z28's Avatar
The new production Super Muncie at http://www.5speeds.com/newm22.html comes to mind. It is totally brand new unit with a much stronger new case and it looks just like the original Muncie.
Rear gear depends on how much of strip or street you will be doing. Generally the 3:70 or thereabouts is considered ideal for street and moderate strip use.
Vince
Old 05-24-2005, 04:57 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Camaro, 327, dependable, cheap, takeoff and speed do not all belong in the same context.
Take cheap out of it. The Muncie as mentioned should do the trick, just remember that if you go to the strip you will need a scattershield.
Old 05-25-2005, 11:53 PM
If you're not planning to initiate any sudden driveline shocks, look at the Saginaw 4-speed. It has available low-gear ratios of 2.54, 2.84, 3.11 or 3.50, and they bolt in where a 3-speed lived with just a shifter change. The wider-ratio versions will give you quicker & easier takeoff without having to use high-ratio rear end gears.
Bigger converter, or lower gears? Gametech Transmission - Rearend 6 04-24-2005 12:49 AM
Race Transmission Slipping brainsboy Transmission - Rearend 8 03-05-2005 08:01 PM
transmission clicking? flamedfordbronco Transmission - Rearend 4 04-18-2004 07:29 PM
Epicyclical gears for 4x4 transfer case mpescatori Transmission - Rearend 2 02-09-2004 02:12 AM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
