Best UV clear over epoxy resin - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2010, 07:19 PM
Last journal entry: New photos
Hello,
I have a project which requires the use of epoxy resin. The project will be an exterior use item and I would like an urethane clearcoat to keep the epoxy from yellowing. Which brands of clear have the most UV resistance or is there much of a difference?
Thanks
Old 02-25-2010, 11:22 AM
BarryK's Avatar
Its not going to make a lot of difference, what clear you use.
If the substrate is one that does not hold up well to UV or a pigment that is 4-5 rating (industrial grade) it is a well known chemical fact that the clear can only protect so much. Worse to best you might be talking six months if an unstable substrate.
Epoxy Prep also sealer question off2wildblue Body - Exterior 3 05-09-2009 02:23 PM
clear sand through bdk1976 Body - Exterior 1 03-13-2009 12:50 PM
Problems with clear; fisheyes, never dries joewhite Body - Exterior 4 10-01-2006 07:05 AM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 07:44 PM
