| View Poll Results: Best V-8? | |||
| Chevy Big Block |
52 | 11.13% |
| Chevy Small Block |
245 | 52.46% |
| Chyrsler "B" Big Block 400 |
1 | 0.21% |
| Chyrsler "LA" Small Block 340-360 |
12 | 2.57% |
| Chyrsler "RB" Hemi 426 |
52 | 11.13% |
| Ford Big Block 429-460 |
11 | 2.36% |
| Olds Rocket |
18 | 3.85% |
| Ford "FE" 390-427 or Cleveland 351, specify in post |
28 | 6.00% |
| Ford "Windsor" 351 and for arguments sake 302 |
28 | 6.00% |
| Pontiac 350-400 |
20 | 4.28% |
| Voters: 467. You may not vote on this poll | |||
LinkBack | Thread Tools |
The interchangeability of the smallblock chevys is what it all comes down to. You can build one heck of an engine for cheap money compared to other brands.
Best V-8 ever made
Guess im all by myself, but i loved the 283 chevy. Back in my day they were easy to beaf up,cheap,easy to work on, and i could go on and on. Also loved the 327.
They Rev And Stay Together. Their Oiling System Is Second To None. Tough As Nails, You Will Find Them In Winning Race Cars, Indeed Vehicles Powered By These Engines Hold Countless Records On Land ,In The Air, And On Water. Wanna Play With A Different Cam? No Problem These Engines Have Adjustable Valve Trains And A Virtually Infinite Number Of Profiles To Choose From. They Are In Dump Trucks, Combines, And Can Be Found Under The Hood Of Every Other Brand Of Vehicle. Ya Want Horsepower? They Can Give You More Than You Can Handle. Gas Mileage? They Can Give You That Too. Durability? They Are Legendary! From Day One The Engineers Pulled Out All The Stops To Make This Engine Better, And Better. For Fifty Plus Years Speed Shops, Performance Equipment Manufacturers, Engine Swap Kit Suppliers Put Together Their Offerings For This Engine Before Any Others-Sometimes Instead Of Any Others. AND THEY ARE STILL THE ONES TO SHOW YOU TAILLIGHTS!!!! If There Can Only Be One King Of The Hill And Indeed There Can Be Only One- You Already Know The Answer. THE SMALL BLOCK CHEVROLET
PS If You Want Even More, Have Room For It, A Driveline That Will Handle It, And Want Such An Engine To Have A Similar Criteria To That Engine Listed Above-You Guessed It THE BIG BLOCK CHEVROLET 'The Other Guys' Have Had Over 50 Years To Prove Otherwise And Failed Miserably In Their Endeavours. And The Only Thing They Have To Look Forward To Is The SBC, The BBC, And Yet Another Engine That Will Eat Their Lunch -THE CHEVROLET LS SERIES. Hmmm, I Seem To Notice A Pattern Here! M |
You Forgot Real 1st Oldsmobile True OHV 304 c i V-8 Engine.
10-28-05
In 1948 Oldsmobile Created 1st True OHV 304 ci V-8 Engine ---In 1949 Cadillac Practically Sued Olds In Courts To Get Rights To This Exclusive Engine,i.e. All Engines Were Patterned After Olds OHV 304 c i V-8! Oldsmobile Stock 304 c i V-8s Held All NHRA Drag Strip Titles 1949 Thru 1952! I Owned 3 Olds -- Stock 49 2 dr Cp 304 c i V-8 And, Modified -50 Olds 2 dr cp 324 c i V-8 Tri-Pwr--No Thing Could Come Close To Even Beating Me ! And, I Still Own Radical Modified 54 Olds 2 Dr H T 371 ci V-8 Tri-Pwr. Oldsmobile Has Become Extinct--Chevy Takes All Credit For OHV Engines & Chevy Did Not Have Its Own OHV V-8 Created Until 1955-- G M Even Copied Olds Rocket Body Styles! Olds Hidden-Covered Up in Anals Of Time,i.e. Was Separate Car Manufacturer Sucked Up By (Greedy Politics Included) G M Corp - Olds If Not Small Car Maker Probably Would Have Become Another Tucker... To See More Information... Visit:http://MeanMother.Com Vincent Auto |
Dollar for dollar you cannot make another run as hard or as cheaply. Olds was good. My first car was a '57 Rocket 88 with the 371 / 4 barrel engine. The weight of them was the killer. Olds did have the interchangeability in that from 1949 through 1964 you could swap engines between cars and the transmissions also were just bolt in swaps. The small block chevy is lighter therefor less mass to get moving. 283's and 327's are getting scarce since they stopped building them around 1970. The 350's and 400's are a little easier to find. I will try to find a donor car for the driveline for my '56 Chevy. I'm not planning on modifying the engine or trans from stock configuration for reasons of dependability. Ill look for a 350/350 combination to use.
If I am not mistaken the Studebaker V8 was built by Packard. A car manufacturer from way back.
not packerd
The engine i am refering too was built by AMC they had a 287ci,298ci,and a 327ci ,willy's kaiser built them it look's like a big block dodge it has a 2 inch thick adapter plate that connect's a TH 400 trans to it it's all OEM.
Bugs, Amen To That!!!! MD
I vote the 235/261 3+3=8 doesn't it? Cheers!!!
Hey 46 CHEVY Fleetline, Close Enough! And Remember 'CHEVY Six In A Row Ain't Made To Go Slow!!!! MD
Ah!!! not alone in this world. LMAO Thanks MD
46 CHEVY Fleetline, The 235's And 261's Were Before My Time But I Noticed Anytime The Old Timers Got Together And Talked Cars They Loved To Tell How The 235's Would Blow The Flathead fords Doors Off. An Older Friend Had A '52 CHEVY CUSTOM (People Couldn't Tell What It Was- CHEVY, merc, Cherc, MEVY ????) It Was Powered By A Built 261 With 3 Dueces, One Straight Pipe For Each Two Cylinders, All The Best Stuff. He Said Back Then The BEST GRIPPING TIRES FOR STREET/DRAG RACING WERE MUDGRIPS!!!! So He Ran A Gorgeous Custom Nobody Could Catch And It Had Mudgrips On It! I Have Had A Lot Of Fun With The Later CHEVY Sixes, As Well As All The Other CHEVY Motors. Indeed If I Close My Eyes And Still See Small Blocks I'll Pull Out A Six To Play With. I've Got A Perfect '61 235 Head. Who Knows, I Might Just Find Something To Put It On! MD
