Best value on double roller timing chain? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 11:17 PM
Hey everyone,
I'm going to replace my gear drive and was wondering who makes the best value (lowest price good quality) timing chain? Its a street / Strip truck. The truck does not get many miles but I would like something that I don't have to worry about down the road.
Chevy 383
magnuson supercharger
xe 274h cam
Predator carb
Thanks
Old 12-29-2011, 12:13 AM
malc's Avatar
Living At The Speed Of Life
Go search Summit, all makes all prices.
Old 12-29-2011, 12:27 PM
Yeah I have a Summit catalog in front of me. I also have Jegs and Speedway catalogs.
What I am interested in is people who have actually run some different brands. If a $20 Cloyes holds up fine then I dont want to waste my money on a $50 comp cams or Edelbrock chain.
Thanks
Old 12-29-2011, 01:36 PM
Thanks
Cloyes manufactures most of the high performance timing sets(regardless of brand) sold in the States. What really matters is that you use a degree wheel when installing the timing set to insure that everything was made correctly. If you dont, then its just a crap shoot as to whether the engine will run right.
Old 12-29-2011, 02:36 PM
Irelands child's Avatar
I have a Summit brand "Tru Roller", with Cloyes numbers. Both gears are steel with multiple keyways for advance and retard.
This is one of them with steel (forged, not billet) gears : http://www.summitracing.com/parts/SUM-G6601/ for about $38.
Not a place to go cheap
Dave W
Irelands child
Old 12-29-2011, 05:44 PM
Cloyes is a good quality set.
Old 12-30-2011, 10:16 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
edit: while were on the subject, would cloyes hex -a-just timing chain set be a good deal?
Old 12-30-2011, 10:36 AM
malc's Avatar
Could´nt find "Acu-just timing chain" but found this
Edelbrock Accu-DriveŽ which is a gear drive not chain.
Cloyes do a Hex-A-Just and a Quick Adjust both quite pricey.
Old 12-30-2011, 03:29 PM
techinspector1's Avatar
Wiki Edits: 326
If you have any plans to play with cam timing (advancing or retarding) or changing cams down the road, then you might want to look at the 2-piece Cloyes timing cover that has a round removeable plate at the cam position. Four small bolts and you're at the cam key, unlike dropping the oil pan and pulling the timing cover to get at it.
http://www.summitracing.com/parts/CLO-9-221/
Old 12-30-2011, 03:38 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Hey everyone,
Chevy 383
xe 274h cam
Predator carb
Thanks
little bit of a hi-jack
but I want to hear about your pedator carb
Old 12-30-2011, 08:05 PM
What about the Predator carb? It seems like people love or hate them. I love em myself
Old 12-30-2011, 10:52 PM
mr mighty mouse
true, i should invest in one down the road, for right no i believe i have a JEGs double roller timing set, or it could be non roller, im intending on using a roller camshaft. Ill google p/n and check it out
Old 12-31-2011, 07:08 AM
& matts38chev
remind me to never try and rob a train or take over a plane
Old 12-31-2011, 02:04 PM
Last journal entry: update
I normally don't chime in after a dozen replies, but I have much experience, and strong feelings, about this.
I've encountered many double roller chains that were stretched after normal use, and precious few that didn't stretch.
As best I can determine, the lowest-cost chain that doesn't stretch is the Cloyes Street Roller.
I make no money off specifying this, I just refuse to use anything less, and can't afford to use anything more.
Old 12-31-2011, 05:22 PM
cloys hex adjust timing set is great.their aluminun 2 piece timing cover is a time saver if you play with your cam timing.i have found you have a clearence problem if your using a short water pump and that cover.
Double roller timing chain GUITAR1989 Engine 3 07-01-2011 05:31 AM
double roller timing chain ?? TheBigDeal Engine 4 05-13-2008 08:31 PM
350 double roller timing chain help..... SideSlip Engine 3 09-12-2005 10:56 PM
double roller timing chain? CurtisL Engine 10 11-04-2003 04:28 PM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
