Best water trap for a compressor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-11-2006, 05:09 PM
3 phase or 3 wire? I seriously doubt that you could get 3 phase power hooked up to a residence especially a double wide even if it happened to be available in the area. This is a completely different hook-up than residential power and is for commercial industrial type buildings and heavy power use shops.
  #17 (permalink)
Old 07-11-2006, 05:26 PM
Wiki Edits: 31
it does have 3 phases, right now it is starting to go bad, it kicks from the third phase to the 1st right after switching to the third, there's somthing going bad in it, and will need replacing soon. around here our power is hooked up the same as a regular house, just there is a pole that the wire is hooked to from the road pole, rather than right to the house, it then runs under ground to the house. is there any other way to wire 3 phase not needing regular 3 phase hookups. this was put in professionally in 1987 so the fire codes probably arn't what they were back then making anything like this a no no.
  #18 (permalink)
Old 07-11-2006, 05:52 PM
I assumed the pump was hooked to your house wiring and I just couldn't imagine a residence wired for 3 phase power. What you have still sounds a bit strange to me but then maybe it is a common set-up.
  #19 (permalink)
Old 07-14-2006, 10:40 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Originally Posted by Jcfoote60
The question I have is what are your opinions about who makes the best water trap?
Jim
I really like this Motor Guard filter. It has an element like a toilet paper
roll in it. I take it out and let it dry every once in a while.
I installed it behind my regular trap and only use that line for painting, a
seperate line off of the trap is for air tools and everything else.
http://www.sjdiscounttools.com/jlmm60.html
http://www.smartshoppersinc.com/moto...otorguard.html
  #20 (permalink)
Old 07-19-2006, 07:15 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
JC-
EXACTLY the unit I was looking for !!!
Thanks!
Jeff
  #21 (permalink)
Old 07-26-2006, 05:05 PM
Best water trap
Try the Tsunami automatic water seperator from suburban manufacturing gosuburban.com. This seperator has a 100 percent money back guarentee if it does not work.
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
Water in compressor lines??? SouthernRodder Body - Exterior 51 07-28-2006 08:33 AM
Compressor newbie question...(water filter) flipp121 Hotrodding Basics 2 07-06-2005 12:01 AM
Air Compressor Water Traps & Tank Reservoir Drains ultgar Garage - Tools 1 01-26-2005 12:01 PM
Compressor Water Problem MI2600 Garage - Tools 8 12-26-2004 06:54 PM
