best way to adjust valves??
What is the best way to adjust the valves on a SBC with a hydraulic cam?? I have a lunati voodo cam and the instructions from the manufacturer say to adjust the valves without the engine running by tightening the nut on the rocker and spinning the pushrod until it becomes hard to spin and then turn the nut an additional half-turn. This will preload the plunger. Once at that point you are to tightening the jam nut. IMO this is a complete ******* of a way to adjust the valves because I can spin the bloddy pushrod when the valve is wide open. I have tried 3 times now to adjust my valves using this method and I can still hear massive ticking out of my valve covers. How should this really be done, I have been told it should be done with the engine running but I tried that too and lost 5 quarts of oil all over my engine and driveway in less then 2 minutes. Please help here because I want to get this done right.
Thanks, Keith
Better Yet use the Knowledge Base on this site,
http://www.hotrodders.com/kb/valvetrain
Luv the smell of NITRO in the morning. |
It's easy with 2 people. Hand tighten all the valves have someone keep their fingers on the valves, when one starts to move down, tighten the other to zero lash (or whatever spec you use). When the other valve moves, tighten the other. That's it. Takes about 1/2 hour, order is irrelevant. |
I have found that rather than spinning the pushrod, it is better to jiggle them up and down. If you're gentle on tightening of the polylock or rocker nut while you're jiggling the pushrod up and down, you can feel just when it snugs up, then go another 1/2 turn and you're good to go.
If you want to set the hyd lifters while the enige is running, warm it up first with the valve covers on. Then slow the idle speed right down as low as it will go.
then remove a valve cover and do the valves. You won;t loose all the oil if the engine is hot and the idle is slow. |
to be safe and make sure its done right order does matter. adjust both valves when the piston is on the top of the compression stroke for that cylinder. there are other quicker ways, but this one is the easiest to follow and understand. As far as preload goes, tighten a quarter turn past zero lash. Yes it really is that easy and straight forward. |
One valve should be at zero lash while the other is moving down. I've done it this way 100 times and for an initial setup it's the easiest, most accurate way. |
If done right is is easier, but its harder to do right that way. |
Ive seen little metal clips that temporarily go on the pushrod side of a stock rocker to direct the oil downward while adjusting. Not sure where to get them though. I used to do like Fbird88 does, idle it down, and also cut a piece of cardboard out and slide it in the outer edge of the head by the valves to keep oil from making a mess. It helps a lot.
The quick old way, takes about 15min.
------------------------------------------------------ Intake-----Exhaust- Top dead center with #1 cylinder valves closed, adjust-- #2----------#8--- Rotate crank 90* clockwise-------------------- adjust-- #1 -------- #4---- Rotate crank 90* clockwise-------------------- adjust-- #8 -------- #3--- Rotate crank 90* clockwise-------------------- adjust-- #4 -------- #6--- Rotate crank 90* clockwise-------------------- adjust-- #3 -------- #5--- Rotate crank 90* clockwise-------------------- adjust-- #6 -------- #7--- Rotate crank 90* clockwise-------------------- adjust-- #5 -------- #2--- Rotate crank 90* clockwise-------------------- adjust-- #7-------- #1--- |
adjusting valves
I have adjusted valves with engines running. I used a old set of valve covers with the tops removed, you have to use the gasket to secure a tight seal. Hope this helps you... jim
Adjusting Hydraulic Lifters On Small Block Chevrolet This method is with the engine OFF and spark plugs removed for easier rotation. Install all the hydraulic lifters and pushrods. NOTE: New lifters do not have to be pre-lubed. Assembly lube should be put on the cam and the mating face of the lifters. Install all the rockers and the adjusting nuts leaving them loose. Do not tighten the adjusting nuts before adjusting the valves. Make sure the pushrod is in the lifter and the rocker arm seat when making the adjustments. Adjust one valve at a time. Rotate the engine in the normal direction of rotation (clockwise looking from the front of the engine) until the exhaust lifter on the cylinder that you are adjusting just begins to move up. At this point adjust the intake valve on that cylinder to ‘0’ lash with no pre-load. Then tighten the adjusting nut ¼ to ½ additional turns. Rotate the engine over again until the intake lifter has come to the full lift and then is almost all the way back down. At this point adjust the exhaust valve to ‘0’ lash and then tighten an additional ¼ to ½ turns. Continue the above for each cylinder until all the valves have been adjusted. NOTE: Rather than spinning the pushrod and attempting to get the correct ‘feel’, I suggest holding the pushrod between two fingers and lifting the pushrod up and down while slowly tightening the adjusting nut. When you reach the point where there is no up and down movement you will be at ‘0’ lash. The problem with spinning the pushrod and attempting to get the correct ‘feel’ is that you can and will still be able to spin the pushrod even if you bottom out the lifter. This can cause you to over tighten the adjustment and can lead to bent and / or broken pushrods and valves. Priming the oil system before starting the engine will fill the hydraulic lifters. |
I still prefer to set the lash with the engine running.. I seem to do somthing wrong when I do them with the engine off.. so I just stopped doing it that way
~but IMHO it makes more sense to do it with it running.. the lifters are operating on their normal oil pressure.. which is how they need to be set. I might be wrong.. but you know what they say about opinions ![]() i cut a window in the top of an old chrome valve cover.. just big enough to get my socket on the rocker nuts.. and it really keeps the mess down. |
| NASCAR, Unleaded Fuel and Titanium Valves | QuenchPiston | Engine | 18 | 12-26-2006 08:18 PM |
| Mixed up valves. | meschnebly | Engine | 4 | 10-07-2003 07:55 AM |
| Cleaning valves | babyface | Engine | 9 | 06-26-2003 03:49 PM |
| 429 Exhaust Valves | BigBlockBabe | Engine | 9 | 03-28-2003 03:24 AM |
| adjust sbc valves with hydrolic lifters | tm454 | Engine | 5 | 11-25-2002 10:50 AM |
