the best way to channel 1930 ford coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 06:41 PM
hello all ,
i chopped the top on my 30 a 5-window , have a pete and jakes 6" z-ed frame with a 5" i-beam drop axle but now want to channel the body down over the frame 6"
any idea's on the best approach ? i had been thinking about the "C-channel approach, utilizing a section of 4" wide c-channel with the sides, or feet being 6" [the amount i want to drop the body. then weld the channel inside the car, above the frame rails, lift off the body and cut the floor strips under the channel out then drop !
seems straight foreward, and i don't have to worry about anything getting sprung out of wack or funny.
thanks in advance
Russ
Old 07-01-2005, 09:23 AM
The floor isn't perfectly flat and straight on these cars so I'm not sure if the C channel idea will work. I think you're best off bracing the interior good before you do any cutting. Good idea to check door alignment often while welding.
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
1930 Coupe Doors? SuperFrog Body - Exterior 3 03-06-2004 05:53 AM
putting a ford in my forty ford coupe john kerr scotland Engine 6 08-07-2003 11:34 PM
gas tanks for 1930 ford 5-window coupe bettylew Body - Exterior 5 01-13-2003 05:46 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
