Best way to clean and renew Aluminum Wheels? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2012, 12:15 PM
What is the Best way to clean and renew Aluminum Wheels?
What products?
What methods?
etc? etc?
Old 06-14-2012, 05:45 AM
S10xGN's Avatar
Gotta love a turbo!
What products?
What methods?
etc? etc?
Cast, billet, or forged? How bad are they? For example, I had a set of corroded Weld pro-stars that were water-pitted so bad that I started sanding them with 100 grit...
Russ
Old 06-15-2012, 09:24 AM
spinn's Avatar
Can you not buff and polish them, and then reclear coat?
I want to say a PPG clear.
Old 06-15-2012, 09:46 AM
Wiki Edits: 27
build a wheel lathe
Years ago I used a wood beam, axle shaft, a lathe live center, welded up some angle iron to hold the axle bearing , to spin and make wide wheels for my dunebuggy a small elect motor and pullies and a jack shaft -long fan belt to rotate wheel as you sand then buff.
How to get aluminum rims clean and polished? valtiel43 Hotrodding Basics 5 05-30-2012 09:52 AM
How to clean old aluminum wheels? enduro54 Hotrodding Basics 30 11-29-2009 08:43 PM
what is the best way to clean cast aluminum steven king Hotrodding Basics 15 08-11-2009 03:43 PM
How to clean/polish aluminum manifold KENMO Engine 5 08-12-2007 04:51 PM
Clean/wax aluminum billet cboy Interior 4 04-11-2004 07:30 PM
