Best way to fix this - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2011, 01:58 PM
What would be the best way to fix these holes on the cab roof? The drip rail is solid and there is no damage to the inside of the cab. I don't want to replace the cab roof if I don't have to.
Old 02-11-2011, 02:13 PM
302 Z28's Avatar
Cut it out, remove all signs of rust, fabricate a metal patch and weld.
Vince
Old 02-11-2011, 02:22 PM
poncho62's Avatar
Wiki Edits: 5
In the drip rail, I believe there is sealer which will melt with heat.....Gonna have to remove that to weld.......
I'm no body man, but I wonder if lead would work in this situation?
Old 02-11-2011, 05:08 PM
Onefunponcho's Avatar
Vince
It really is just that easy,,, Poncho62 was correct also, many vehicles use seem sealer in the drip well. A wire wheel on a drill or angle grinder will clean that out in a jiffy.
Old 02-12-2011, 10:00 AM
deadbodyman's Avatar
Wiki Edits: 11
You can warm that sealer up with a small propane torch and it'll be a lot easier getting it out.It can be very thick in some cars..
