best way to fix "chipped" paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 01:37 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Hello all,
Another question to reveal my ignorance. The paint on my dash, ('56 panel truck), is about 20 yrs. old or so. It shows no signs of peeling, it is just faded and not the color I want. My intent is to scuff and paint, but there are a couple of small chips, (1/8" or so in diameter), in very visible areas. While I have stripped and epoxied nearly the entire EXterior, I wanted to avoid the mess of stripping the dash to bare metal. If the dash was painted in the same manner as the exterior, then there are a couple coats of primer and a couple of coats of paint. What is the best way to fill these chipped areas? Spot prime until it sands level? spot putty? As always, I appreciated the help,
James
Old 07-27-2011, 02:47 PM
Originally Posted by Hwyhogg
Hello all,
James
no reason to go to bare metal. use a little spot putty to fix the chips.
Old 07-28-2011, 05:30 AM
Old Fool's Avatar
I also suggest a spot putty, but not the old skool lacquer types. Use the new 2k spot putty and it won't turn into a problem later.
Old 07-28-2011, 07:01 AM
deadbodyman's Avatar
Wiki Edits: 11
Same here....Two coats of putty applied with a razor blade works pretty well on small stuff...
Old 07-28-2011, 12:26 PM
Hwyhogg's Avatar
Thanks guys ....trying to work smarter, not harder here. Of course, sometimes it takes both..
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 08:18 PM
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
Buffing Out Single Stage Paint "From a Production Shop Perspective" x711 Body - Exterior 18 12-28-2006 11:27 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 01:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
