Best way to flush brake fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2008, 09:48 PM
What's the most effective way to flush out all the brake fluid? Which is the best way: vacuum, pressure, or gravity? Any equipment or tools I should buy?
Thanks,
Rob
'67 Plymouth Barracuda
Old 12-21-2008, 11:44 PM
Wiki Edits: 27
flush fluid
I don't think you will get ALL the fluid out without disassembling the system. YOu could get most out by opening the bleeders, sticking a hose over it to catch it... then making a pressure cap out of an old cover... you could drill a hole in then blow the air into . then flush with fluid that way you would not have as much mixing with old and new fluid. you might have to pump the pedal as you flush... In the factory we used to pressure fill the brake system thru the master cyl.. the bleeder catch hoses were clear so the tech could see when the air bubbles stopped..
Old 12-22-2008, 02:03 AM
4 Jaw Chuck's Avatar
I just bleed the brakes through the front calipers until most of the fluid is out of the reservoir, then top up and bleed all the brakes until I get fresh clear fluid at all the brakes.
Might have to top it up twice to get fresh fluid through all the lines.
Old 12-22-2008, 06:25 AM
Should I flush the fluid by simply opening-up (one at a time) the bleeder valves and bleeding by gravity (no pumping of the brakes) or should I buy some sort of vacuum bleeder like the ones made by mityvac, kdtools, lisle, or vacula?
Here are my choices:
http://www.sears.com/shc/s/p_10153_12605_00947746000P
http://www.sears.com/shc/s/p_10153_12605_00999096000P
http://www.sears.com/shc/s/p_10153_12605_00947058000P
http://www.sears.com/shc/s/p_10153_12605_00999499000P
http://www.sears.com/shc/s/p_10153_12605_00996273000P
http://www.sears.com/shc/s/p_10153_12605_00942276000P
http://www.sears.com/shc/s/p_10153_12605_00999782000P
http://www.sears.com/shc/s/p_10153_12605_00947323000P
I'm planning to buy at Sears since they currently have a no interest and no payment offer for 1 year and the prices seem reasonable. Which one should I get?
Old 12-22-2008, 07:57 AM
Best thing I have found for this is the Motive pressure bleeder. I have a mityvac silverline vacuum pump that worked on everything but my wife's car, could not get a firm pedal with it, think it was drawing air around the bleeder screw threads. Put the Motive on it, firm pedal the first time. It is easy to one man bleed the brakes, hook this to the master cylinder & pressurize to make sure there are no leaks, depressurize & add fluid then pump back up & open bleeder screws one one a time till clean fluid comes out. I flush all the fluid out of my cars about every 2 yrs like this.
Old 12-22-2008, 08:58 AM
Irelands child's Avatar
I have a Mity Vac, and quite frankly find that it's about useless for a full brake system bleed (sorry to those that like them - that's my experience). What I've done is install Russell or Dorman speed bleeders and just pump a bunch of fluid through the lines, one at a time. If you really want to be meticulous and messy, flush with a very good grade, low/no water, of isopropyl alcohol(not drug store stuff), which will serve 2 purposes - first it will clean out most of any sludge, and secondly since it's hygroscopic, it will carry out any water. Then refill with a very high boiling point brake fluid, maybe DOT4 (not DOT5 as that's silicone, and that's for another discussion)
Dave W
Irelands child
Old 12-23-2008, 03:49 PM
I have always tried to avoid pressure because of the potential and likely mess. Gravity bleeding works often as long as you are willing to wait a L O N G T I M E .
I choose vacuum bleeding. My setup cost me all of $20 and works very well. So far the only mess that I have made is spilling a jar of brake fluid on the driveway after taking the lid off. No pressurized brake fluid spraying on my paint and it actually cleaned off a grease stain the driveway where I spilled it
Don't pay $100+ on credit for something you could so simply and cheaply make for yourself. Those hand powered vacuum pumps suck for bleeding brakes but work ok for testing vacuum actuated stuff (timing, egr, etc.).
Check out the wiki article I started on vacuum bleeding
http://www.crankshaftcoalition.com/w..._brake_bleeder
Originally Posted by Irelands child
...What I've done is install Russell or Dorman speed bleeders and just pump a bunch of fluid through the lines, one at a time...
I have used those as well. They work great but I don't have them installed in all my vehicles let alone all the vehicles I work on (family/friends cars). I still use the jar I made for the vacuum bleeder to bleed into with the speed bleeders.
Old 12-24-2008, 12:30 AM
JeffB's Avatar
Brake bleeder
A lot of guys talk about Harbor freight selling junk but this I have give It worked fantastic! My '54 Ford sat for a lot of years,I replaced all the wheel cylinders and hoses and converted to a dual master(which I forgot to bench bleed,OOPS!) You attach an airline from your compressor to this unit and follow the directions,the whole system was bled in less than 10 minutes and fluid running clean and no air.My neighbor has used it several times and says it is great also.Here's a picture, runs about $30, pedal pumping is a thing of the past one man operation.
Name:	brake bleed.gif
th125 fluid flush... now broke? mrunexpected Transmission - Rearend 1 07-03-2008 11:32 AM
Where's my brake fluid going?? STATUTORY GRAPE Suspension - Brakes - Steering 7 05-22-2008 06:24 PM
Flush your lines! Dave57210 Suspension - Brakes - Steering 1 02-12-2008 12:26 AM
any sealer impervious to brake fluid? oldguy829 Suspension - Brakes - Steering 16 04-01-2007 02:45 PM
brake light on, could it be a bad master cyl Turbo Terror Suspension - Brakes - Steering 4 03-07-2006 07:04 AM
