Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best way to get around 900-1100 hp outta a chevy engine
  #16 (permalink)
Old 01-15-2009, 09:25 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Here you go...
Get your check book ready...
http://www.dyno-flo.com/
Street 598 Pump Gas 820HP
•Dart Big M 10.2 Deck Nodular Caps 4.600
•JE Pistons Forged Race 10.5:1 w/ Ceramic coated crowns for more power
•Eagle 4340 Forged Steel Internal Balance Crankshaft 4.5 Stroke BBC
•Eagle 6.7 4340 Forged Steel H Beam Rods with ARP L19 Rod bolts
•King Alecullar Pro Race Bearings Rods and Mains
•Mahle File Fit Performance Ring Set
•Balanced and Assembled
•Dart Pro 1 345 CC Alum Heads- Fully Ported and Flowed
  • 118cc Chamber w/ ceramic coatings on Chambers/ Valves- for thermal efficiency and power
    Assembled For .750 Max Lift
    Stainless Valves
    1.63 Valve Springs
    Titanium Retainers
    10 Degree Locks
    ARP Headstuds
•Mr. Gasket Solicore Head Gaskets or Equivalent
•Dart Single Plane Intake Manifold
•Comp Cams Solid Roller Custom Camshaft
•Comp Cams Solid Roller LIfter +.300
•Melling High Volume Oil Pump and Shaft
•RPM Fluid SFI Internal Balance Damper
•Moroso 21047 Eliminator Pan or Milodon Jet Drive Marine Pan
•Billet Race Double Roller Timing Chain
•Aluminum Valve Covers
•Dyno+Tune
$11,999
Add some spray to make up the extra 80-280 hp.
