best way to identify a rear end ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2011, 10:53 PM
Hi guys, i have a GM 10 bolt rear out of a 67 firebird and i need to find out what the rear end ratio is. What is the easiest way? the cover is off and the rear end is on my bench, gears exposed. i tried the serch function but i didnt come up with much. thanks for your time
Old 02-20-2011, 11:01 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Divide the number of teeth on the ring gear by the number of teeth on the pinion. ala, 37 divided by 9 = 4.11.
Old 02-20-2011, 11:02 PM
excelllent, thankyou very much for the quick reply.
Old 02-20-2011, 11:07 PM
SSedan64's Avatar
The Ring & Pinion tooth count #'s should be stamped on the Ring gear also.
Old 02-21-2011, 08:50 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
here is a WIKI article on ratio check:
gear ratio check
it is basic car guy 101 info that is needed
Identify rear end jamn50 Transmission - Rearend 6 11-28-2010 10:29 PM
Help identify this rear end please Mitchman Transmission - Rearend 5 11-24-2010 06:47 AM
Please help me identify this rear end. Nomad Crow Transmission - Rearend 7 10-22-2009 06:52 PM
Help me identify my rear end. Gr8 '48 bow tie Transmission - Rearend 6 06-03-2006 11:36 PM
Help Me Identify My Rear End 70SPORT Transmission - Rearend 4 05-22-2004 11:23 PM
