Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best way to insert a mechanical trans temp gauge
Old 08-10-2012, 02:48 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
I am not familiar with your trans but if you can use a port thats already there then that is the easy way out. With my 347 Ford i use a Milodon sump and i fitted an oil temp sensor by drilling a hole in the sump and then making a fitting from aluminum and securing it to the sump with about 7 stainless metal threads and some high temp rtv. Works well. ( the sump was off the engine of course)
Al.
