Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best way to insert a mechanical trans temp gauge
Old 08-11-2012, 08:33 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by rusthater89 View Post
Which line is the one that feeds the cooler?
Bottom cooler fittin in the T-350 is the ''out'' from the trans.
Oil directly out of the converter. Temps there can be high depending on your trans / converter setup
