Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best way to insert a mechanical trans temp gauge
Old 08-11-2012, 06:36 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by rusthater89 View Post
I took a peak at my trans today. I noticed three different pipe plugs on the housing. Which one is the pressure port? Or does it not matter.
the port at the rear of the case near the vacuum modulator area is the main line pressure port
