-   -   Best way to insert a mechanical trans temp gauge (http://www.hotrodders.com/forum/best-way-insert-mechanical-trans-temp-gauge-222717.html)
rusthater89 08-09-2012 03:28 PM
I wanna install a trans temp gauge on my th350. The only idea I have is to use a t-pipe on the trans cooler line. Also which is the line that feeds the fluid to the cooler.
the california kid 08-09-2012 11:38 PM
rust
nooo.
trans temp gauges go in the side of the pan.
have a nice day!
Calderone 08-10-2012 02:17 AM
i installed it on the pressure test port on the case , works wonderful and it fits perfect !
i removed one shifter fastener and i got the wire thru that hole.-
Easy and clean !
67Mustang Al. 08-10-2012 02:48 AM
1 Attachment(s)
I am not familiar with your trans but if you can use a port thats already there then that is the easy way out. With my 347 Ford i use a Milodon sump and i fitted an oil temp sensor by drilling a hole in the sump and then making a fitting from aluminum and securing it to the sump with about 7 stainless metal threads and some high temp rtv. Works well. ( the sump was off the engine of course)
Al.
big gear head 08-10-2012 06:41 AM
Cut a pipe coupler in half. Drill a hole in the pan and weld one half of the coupler to the pan. Put the sender in there.
302 Z28 08-10-2012 08:57 AM
Pressure test port on the side of the trans.
Vince
SSedan64 08-11-2012 04:31 AM
Pan, Test Port or Line IN/Return from Cooler.
The line OUT/Feed to Cooler will indicate a much higher temp, it comes straight out of the TC/TorqueConverter.
rusthater89 08-11-2012 07:10 AM
Which line is the one that feeds the cooler?
Crosley 08-11-2012 08:33 AM
Bottom cooler fittin in the T-350 is the ''out'' from the trans.
Oil directly out of the converter. Temps there can be high depending on your trans / converter setup
rusthater89 08-11-2012 05:08 PM
I took a peak at my trans today. I noticed three different pipe plugs on the housing. Which one is the pressure port? Or does it not matter.
Crosley 08-11-2012 06:36 PM
the port at the rear of the case near the vacuum modulator area is the main line pressure port
rusthater89 08-11-2012 07:09 PM
Thanks.
I am gonna try to put the gauge in that.
the california kid 08-11-2012 08:14 PM
1 Attachment(s)
hotrodders
here's a pan with the fitting already in it.
Derale GM TH350 Transmission Cooling Pan - Speedway Motors, America's Oldest Speed Shop
plus you get deep pan and cooling tubes.
this is the good guy way to do it.
have a nice day!
rusthater89 08-14-2012 08:39 PM
Originally Posted by the california kid (Post 1582065)
hotrodders
have a nice day!
Nice, I wish I had more money. The things I would do to my car.
302 Z28 08-15-2012 07:44 AM
hotrodders
have a nice day!
That pan is nice if you have the ground clearance for it.
Vince
