Best way to pull an engine from a full size GM van? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2005, 09:30 AM
Gearhead forever's Avatar
Wow...what a tight looking spot. I'm assuming the engine has to come out the front instead of through the door? any tricks to make this easier? The van is the '70-96 bodystyle.
Old 04-12-2005, 09:34 AM
MI2600's Avatar
Member# 3287
My son-in-law pulled one from an '89 van. He said they had to remove A LOT of the front end, but were able to get a cherrypicker in there.
Old 04-12-2005, 10:05 AM
bullheimer's Avatar
NEVER use credit cards!
i took one out thru the side door. but understand the front is the way to go. i couldnt figure out how to get it off tho.
Old 04-12-2005, 10:17 AM
dei8fan's Avatar
Registered Brain Surgeon
If you have a lift out the bottom is the easy way. Unbolt the engine crossmember and lift the body off.( This is how we do it at the salvage yard when you dont have to put it back together)
Old 04-12-2005, 07:32 PM
Thanks guys.....It will be in my driveway....so its the cherry picker route
Old 04-12-2005, 07:55 PM
poncho62's Avatar
Wiki Edits: 5
The grill, rad crossmember and rad etc has to come out. If you jack the front end up about a foot or so, it makes the cherry picker easier to get in under the dash.
Ontario Rodders
Old 04-12-2005, 08:44 PM
302 Z28's Avatar
As above, right out the front.
Vince
Old 04-12-2005, 09:14 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
ive done it out the front its a tight one take off the hood grill rad a/c condenser all the acc. including the carb and dist I also took off the motor mounts, cups and towers get one of those mounts that mounts to the intake where the carb goes and make the chain as short as possible if you can loosen up the crossmember
good luck
sr66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 04-15-2005, 06:33 AM
Thanks again for the tips guys.
Old 04-16-2005, 07:04 AM
MadRabbit's Avatar
ya just need a bigger hammer
I helped my bud pull one out the passenger side door with a picker..but it looks like it can be done allot of different ways.His is a 81 chevy vandura
Old 04-16-2005, 01:23 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Out the front is the way to go.Iv'e even pulled the intake and heads to give me more room so it was easier to pull though the firewall.
Old 04-16-2005, 05:40 PM
CrashFarmer2's Avatar
Dried up in the Drought! :(
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Yes, out the front and it is tight.
Old 04-17-2005, 07:31 PM
Rob Keller's Avatar
Wiki Edits: 38
obviusly you want to put one back in right?/
cause the easiest way is through the roof ( man i miss workin in the bone yard ) yes i will admit ive killed more cars and trucks than ive fixed there is a deep satifaction in crushing a yugo ... k cars go really flat ah hh hh sorry i digress
sr66
"SlowRide66"
Old 04-23-2005, 04:23 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Yep! Out of the front. I took off near everything that was up there. Took me most of a week. But then that was the first engine I ever pulled. (with help)
Old 04-25-2005, 12:49 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Its a Ford, but this is how it came out
hotrodders.com/forums/journal.php?action=view&journalid=20616&page=3&per page=5&reverse=
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
83' Chevrolet FULL Size Van.CALLED??? Stick'n It Hotrodders' Lounge 7 07-11-2004 11:48 AM
FWD 2.8 gm engine into rear drive vehicles musky2 Engine 0 01-02-2003 01:18 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
GM Engine Mounts johnnymopar Engine 5 08-29-2002 02:03 PM
