Best way to raise the rear end on 66 Nova? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2004, 06:53 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
The rear tires on my 66 Nova rub if I go over heavier bumps. I wondered if there is any way to raise or extend the shock mounts to accomplish a lift.
Old 05-12-2004, 09:33 AM
Wiki Edits: 49
The simplest and easiest way would be a set of air shocks.
Centerline
Old 05-13-2004, 01:36 AM
Air shocks work, but if they go flat, you have rubbage again. Find a local spring shop that can re-arch the rear springs. If you do use air shocks, be sure you plumb the air lines separately. Otherwise the body will roll excessively in turns.
