Best way to remove surface rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2006, 01:42 PM
This question has most likely been asked but I have not found it on the site. What steps would I take to remove the suface rust on the hood of my 71 GMC. The rust pretty much covers the entire hood and is rather rough (very little paint left). Would I use a paint stripper or rust desolver before sanding, and if I paint it with epoxy primer, do I have to have every trace of rust off or will the epoxy seal to prevent rust from reappearing?
Old 10-31-2006, 01:49 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
There are many ways to do this, and I believe if you do a Search you will find a lot of answers-my personal favorite would be to get it star blasted (media blasted)-it will be clean, ready for Epoxy and Bondo (if that's your style), or you cn look at this:
secrets of surface rust removal revealed
Old 10-31-2006, 02:50 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I'm using the naval jelly right now on a roof. It's slow, but the rust does come off. I've been letting the jelly sit and then go back and scrub. See my journal for more pics.
Before:
http://hotrodders.com/journal_photos...1620882021.jpg
After:
http://hotrodders.com/journal_photos...1620895390.jpg
Old 10-31-2006, 03:49 PM
Wiki Edits: 31
get a blow up kiddie pool, fill it with water, put your hood in it, add some baking soda to the water and apply an electrical charge to the metal. it will dissolve the rust.
Old 10-31-2006, 07:32 PM
Tell me more!!
Can you go more in depth on this procedure? Thanks
Old 10-31-2006, 08:30 PM
Wiki Edits: 31
ok, it is actully more of a farmer trick for removing rust from engine parts, such as crank shafts and such, on a large scale it would still work tho ( such as this hood ). I'm going to describe it as if your doing a crank shaft, some people will stick both leads in the water with the baking soda mixed in, works but you could also charge the crankshaft positivly and put the neg in the water, on a crank shaft, just wrap some stripped 2/12 romex ( actully, get the ground wire, save time ) around the end of the crankshaft and hang it in a drum of water/ baking soda with a rope, then connect the pos lead to the 2/12 romex, put the - lead ither on the drum or in the water. you can use a trickle charger as long as it does not have a float mode, if it provides 12v at all times then it will work, or a big battery charger set on a low setting, or a 12v battery, but with a battery you must enshure that voltage is dropped thru the resistance of the water ( or your just crossing terminals ) . you could enshure this by connecting a test light from the water to the 2/12 romex, it will light up and become a load on the battery, enshure that current is flowing thru the batt and there is voltage drop. normally none of this is a problem but batterys can explode, so take all precautions
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 13 11-15-2015 08:09 AM
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 07:23 AM
Surface rust 57halfton Body - Exterior 2 07-29-2006 05:00 PM
Newbie surface rust question. BMM Body - Exterior 2 07-22-2006 07:14 PM
Completely covered with surface rust...HELP richall Body - Exterior 18 11-11-2002 10:24 PM
