Originally Posted by bigdog7373
So you're pulling the engine/tranny now? Thats good, will make it much easier. Remeber the trans cooler lines are bolted to the oil pan on the passengers side. They will bend if you dont disconnect them from the engine. This is assuming you have an auto and the engine hasn't been out before.
Thanks for the tip. I'll check the trans cooler lines. The engine has been out. Someone put a sb Chevy 350 in it but it still has the BOP Turbo 350 Transmission.
It fooled me. I put in 3.73 rear gears a few years back (stock had 2.42 gears.) I bought chevy speedometer gears and what bummer that was to realize I had a BOP trans all along.
I'll be busy the next few days but like I posted before hopefully it will be out this weekend.
