Best way to remove a trans am sub frame - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 08-04-2012, 12:15 PM
rusthater89's Avatar
Originally Posted by cdminter59 View Post
I use this engine lift from Summit Racing and pull my big block 454 with transmission together. Summit Racing SUM-G1015-1 - Summit Racing® Engine Lift Plates - Overview - SummitRacing.com. I used new 1 1/2" studs to bolt it to the intake.
I was considering that but I ended up buying the harbor freight load leveler. It attached right onto my intake bolts.
how to remove cab off frame.... unearthly57 Body - Exterior 22 11-15-2011 07:01 PM
77 Trans Am Frame/Suspension setup Tomlowe523 Suspension - Brakes - Steering 4 09-30-2009 02:49 PM
Olds trans remove 85406 Transmission - Rearend 3 07-11-2006 06:10 AM
How do remove motor mounts from frame? In_Style Hotrodding Basics 5 10-12-2005 07:52 PM
how to remove ignition lock cylinder on a 1981 trans am stoney 81ta Electrical 9 12-13-2003 07:30 AM
