I got a 671 blower and I was wondering what would be the best way to run water injection on these? The only way I can think of is running a spacer thats been tapped for the nozzles under the carbs. I would like to avoid using spacers, is there an alternative that I haven't thought about?
You can contact the companies that make those system's (like Snow) to see if they have any suggestions. I'll be putting water injection in my truck (non-blower/turbo), but as far as I know it needs to be injected under the throttle plates.
I too have wondered that, but moreso about making my own kit. Also, you hear of folks pouring water down the carb throat at high speed to clean the carbon out of the motor. So, I took a plastic irrigation solution bottle (hospital item, 2 liters), and filled it with water and a little rubbing alcohol, put a small diameter tube into the container and the other end onto the vacuum advance nipple of the carb. This was on full centrifugal advance ditributor setup, and drove around that way. Did'nt seem to hurt anything, can't say it helped, but I reasonned that the engine would pull more vacuum under load, and therefore more water ,to stave off detonation. Could one "tune" it with some sort of jetting, and would that work?
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
