Best way to set carb screws - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 06:21 PM
sudo1a's Avatar
Post Best way to set carb screws
It has been several years since I tuned a Carb. I have a Vacuum gauge and was wondering where a good starting point is for my 750 edelbrock Carb. There are two screws. Do you just turn them until you achieve maximum vacuum? Help me out, my brain is locked.
Old 12-17-2002, 07:14 PM
bullheimer's Avatar
NEVER use credit cards!
Post
screw all the way in, then back out a turn anda half.
Old 12-17-2002, 07:17 PM
Post
I just tuned my edelbrock carb today i always back the screws out 1 3/4 turns then go from there until im running around 18-20 on the engine vacuum guage.
Old 12-18-2002, 01:00 AM
E.T. divided by $ spent= Speed
Post
I start 1 1/2 turns.Then tune one side till it idles highest,rev it to clean it out then do the other side.Then I go over it again.
Old 12-18-2002, 06:36 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
All the tuneup books recommend tuning it with a manifold vacuum gauge and tach. Work from screw to screw to idle speed until you achieve MAXIMUM vacuum at recommended idle speed.
