Best way to store a crank shaft?
Whats the best way to store a crank shaft? Is it better to sit it on its butt or lay it across the throws?
Thanks Steve |
I was always taught (right or wrong) to store it on end -Flywheel side down-
Like Tom says...if it falls over, that will hurt it more than it laying on it's side. Hang it. Build a slotted shelf so it can hang by the back end.
Ontario Rodders |
I store mine on end in a way that they can't fall. In my situation I have mine behind my air compressor. I have one crank right now that doesn't fit behind it, so I just wrapped it in an old blanket and set it on end. If it does fall, at least it won't damage it.
I have seen guys use the snout bolt and drill a few holes in a shelf. They just hold the crank up to the shelf and thread the bolt through the hole. I did that once and dropped a cast Caddy crank from chest height on a cement floor. I gave up on that idea.
what?
If you want to have it rebalanced, lay it on the side, pay the machine shop again.
Or, store it upright, hanging, is probably safest though watch your head. Bolt the flex pate on and use tha as a stand, or last but not least, make sure it is upright. Best to worse of the three. |
It is not round
It is not a rod, it has weights plural. Eack weight wants to go its own way. Gravity is still an issue even though it is metal. Not only from a crank getting thrust around inside an engine block, but it gets heated and cooled and heated and cooled, etc... The more true a crank is to being balanced, means less friction, less resistance. I want my crank to not slap up and down or side to side or twist. I want it to be as balanced as the guys at the machine shop can get it. And when a master engine builder tells me that I need to store it upright and not on its side and explains what I explained, as well as my going to the machine shops enough times and seeing and talking to a few machinists, I am not asking again. His name is Tom Varrenti. He is in Penn Hills, PA. Credentials to my knowledge. Hotrodding since the 50s, back and forths with Jack McDunah or however his name is spelled, 1977 Nationals from all over the country in PA, was only person left standing from Keystone on Sunday and red lighted. Did it all on his own money and was the only white camaro without an endorsement. B&R represented the other 11 guys. Ask CraneCams if they know of him?
He puts an engine together and he does it right. His crank assembly let alone his engine assembly is tops. Smooth as silk is spins. That's why, don't store it on its side. Dang, sorry for the long windedness, but didn't know on how else to explain my knowledge of that.
OK...now that that's settled, let's dicuss laying camshafts on their side.........................
Ontario Rodders |
I would think that anything with that much metal would be plenty strong due to what it is. It takes a lot of stress that would be a little hard to duplicate outside of an engine. I would imagine that it could be laid on its side without any trouble.
| Recent General Rodding Tech posts with photos |
| strocked 305 400 crank ideas???? | ace29816 | Engine | 10 | 01-04-2008 06:26 PM |
| Repairing a damaged crank by welding.. | Old School Nut | Engine | 7 | 05-10-2006 08:05 AM |
| forged crank question | Ratoflic | Engine | 2 | 04-18-2006 04:50 AM |
| crank problem | Zartan | Engine | 17 | 05-11-2004 02:39 PM |
| possible to warp the crank shaft? | greaser_gurl | Engine | 5 | 04-02-2003 08:48 AM |
