-   -   Best way to tap dings out of a painted surface? (http://www.hotrodders.com/forum/best-way-tap-dings-out-painted-surface-219775.html)
Ripped 05-24-2012 05:08 PM
I have a small dent (Projecting out), on my painted front fender.
Easily accessable
Obviously, if I just hammer and dolly it, it will damage the paint.
What is the best way to tackle this?
Would covering it up with a few layers of masking tape, prior to using a hammer and dolly,be sufficient protection?
Thanks
Cape Cod Bob 05-24-2012 07:44 PM
practice on another car first, maybe at the junkyard.Use something soft on the finish side and hammer from the backside.
oldBodyman 05-24-2012 10:32 PM
"Would covering it up with a few layers of masking tape, prior to using a hammer and dolly,be sufficient protection?"
Better to put 4 - 5 layer of tape on the hammer face so you see what you're doing.
Be sure the backside of the fender is clean also, any dirt or crud will get imprinted into the fender as ripples.
Godd luck with it.
MARTINSR 05-24-2012 10:53 PM
Another trick is to use a wooden golf tee with a blunted end to hit with a hammer. The paintless dent guys use a plastic version of this, I got a few but before I did it was a blunted golf tee for me.
35WINDOW 05-25-2012 06:56 AM
I have a Ford Pickup that I bought new in 1995 (I'm still not sure why I keep it, but it's in like new condition)-anyway, I put in some new high end Speakers for my Stereo, and I used too long of a screw, which pooched out the metal on the outside (it's in the rear corner of the Cab)-
Anyway, I took it to a paintless dent repair shop, and he used a white plastic (Delrin?) type of tool that had a blunt end, and used it in a tuck shrinking method type of motion and you cannot tell that an idiot was at work (me!)- :sweat:
I would suggest talking to a PDR guy-
sparkydog 05-25-2012 07:01 AM
Use a hot water bottle (filled with water) as a dolly.
rusthater89 05-25-2012 08:11 PM
put masking tape on the hammer and dolly. Sorta build up the tape a bit. It will work. I've done it a few times.
Ripped 05-26-2012 10:56 AM
Great, thanks guys. As always lots of great tips :)
I'll let you know how it goes.
