Best way to tone down exhaust? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2012, 10:48 PM
I just finished my rebuild on a 50 chevy pickup with a 350 chevy that has a small Weiand blower. The dual exhaust is 2.5 inches, Sanderson headers and Spintech mufflers. The exhaust system has also been ceramic coated. Looks great too, but just too loud. When I drive it, the drumming sound kills my ears and I have good insulation in the cab. How can I tone down the exhaust system? Could I add some type of silencers in-line so that I don't have to replace the exhaust system completely? I paid $600 for the exhaust and another $200 to coat it so hoping to do this without scratching the whole thing. Any thoughts would be very welcomed.
Old 08-15-2012, 11:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Add some resonators in the rear..they are small mufflers and can do a lot to change the exhaust note..Get the stainless ones and you will not need to recoat anything..
Sam
Old 08-16-2012, 04:39 AM
Install a set of dynomax bullets and a crossover pipe.
I built the exhaust system on a friends car. It had the same droning problem. So, I added a H-pipe after the transmission then a dynomax bullet on each side after the H-pipe and that fixed the problem. New cars also use multiple mufflers to get the job done.
What is a spintech muffler?
Old 08-16-2012, 05:37 AM
Last journal entry: Still running strong
Summit & Jegs have these cone shaped stainless screen things,I dont know what there called,but they slide into the collectors.Should help tone it down some.
Old 08-16-2012, 06:58 AM
cheap experiment would be a set of short glasspacks to act as resonators at the end of your exhaust. I think cherrybomb even sells some polished trim rings to put on the end of the glasspack to give it a finished look.
Old 08-16-2012, 07:12 AM
Banned
For a drone an x pipe helps a lot. To lower the volume you'll need different mufflers.
Also, be sure you have enough timing advance (and vacuum advance) this can lower volume a lot.
Old 08-16-2012, 07:57 AM
vinniekq2's Avatar
I use a 3 inch system . The big difference was when I had an X pipe installed.took away all the low RPM drone and dueling 4 cylinders are not as pleasing a sound as dual with x pipe (both tailpipes sound like an 8)
Old 08-16-2012, 02:53 PM
Cridder's Avatar
Last journal entry: 310 Small Block Chevy
Load pipes save lives
Ive been playing with the exhaust on my 05 P-71, i installed magnaflows and its gone from dead quite to a little loader than i like. all the loadness is at the exhaust tips (not much coming from the glasspack body) someone was telling me the the sound waves at the back can ossolate side to side and set up a resonate, a drone, and depending on pipe size and engine the intensity could vary alot. im gona try and rotate my tips so they aim away from each other.
Im also looking for some kind of exhaust tip that can reduce the bark.
Old 08-16-2012, 07:15 PM
I have a nephew who runs a muffler shop. We were talking not too long ago and he advised this was a common problem when customers who installed performance exhausts and removed catalytic converters. He advised replacing the converters with short glass packs would break up the resonation that causes it to be so noisy in the vehicle.
Old 08-17-2012, 06:34 AM
67Mustang Al.'s Avatar
I had a similar noise problem described above with my 347.I have heavy insulated the interior of the car and trunk but still had resonating coming through. My system from the engine back has long tube headers, into 2 1/2" , then x pipe , flowmasters and out the rear about 4" past valence.
I went to the local Harley dealer and bought two multi fluted baffles about 10" long and 2 1/4" diameter. I wrapped them in stainless steel wool and wired the wool in place around the baffles so they could slide up inside the 2 1/2 " pipes with a light push. I then made up two end caps on the lathe out of aluminium to keep these baffles in place and held them on the end with two grub screws in each end ring or end cap. Works well and took the bark out of it. Probably a little too quiet nowl.The baffles were about $15 each i think.
Al.
ID:	67485   Click image for larger version
Old 08-17-2012, 07:17 AM
Ahh the memories of being a kid.
1st one is burning the glas packing out of my thrush glasspacks
2nd one is blowing one of those baffles out of my street bike (SL175 aww yeah) and having another 50 miles to go...ugh that was a LONG 50 miles
Old 08-17-2012, 07:36 AM
I second that. I recall yrs ago when i was a kid on a 750 Honda 4 blowing off a single headlight behind me one night only to find out at the next set of lights it was a cop on his bike. THey had 450,s.
hmmmmm. My bike had a noisy straight out 4 into 1. Too noisy for the coppa.
Al.
Old 08-17-2012, 07:43 AM
you young punks on your hotrod bikes!
I had a 74 Rickman 125 Dirtbike set up as an enduro; a Hodaka Combat Wombat (no really, someone gave Hodakas the best names ever), and the SL175.
All my friends thought I was weird (no kidding) because I liked 'old junk' which I considered 'vintage' and 'off beat'
Old 08-17-2012, 07:57 AM
Unreal i remember the "combat wombat" I had a montesa of similar age. Better start a bike thread from yrs gone by. ( Still have a Duke in the shed)
P.S we have wombats close by our neighbourhood.
Al.
Old 08-19-2012, 01:14 PM
Thanks for all the great advice. I will look into each of your suggestions and see which one is the best alternative for now. I knew I could count on Hotrodders for the answers.
Exhaust tone/downturns question BMM Hotrodding Basics 14 02-08-2008 11:42 AM
Two Tone Paint Bob D. Body - Exterior 5 05-26-2006 05:18 AM
What color two tone to use. Fordy8man Body - Exterior 1 09-26-2005 06:47 AM
Getting the tone. hunt101 Hotrodders' Lounge 10 04-27-2005 06:39 PM
2-tone paint Jason@airride Body - Exterior 2 07-22-2003 07:00 AM
