Best way to weld on ball joint sleeve - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2014, 10:47 AM
Mutt's37Buick's Avatar
So far have not found instructions for welding ball joint sleeves.
Can someone with experience modifying control arms with a ball joint sleeve tell me the best way to weld on threaded ball joint sleeve?
See picture of control arm.
I have lower control arms that were designed for a downward facing bolt-on ball joints. I need an upward facing ball joint that will fit a Camaro drop spindle. I have bought Moog K719 ball joints which are "Small Chrysler" screw-in ball joints used on lower control arms of 73 Dodge Charger. They fit the Camaro spindle perfectly. I have bought threaded sleeves that are designed to hold these ball joints.
I have read to weld slowly to allow cooling to prevent warp of the sleeve.
I will have to cut a hole for clearance of the ball joint.
My question relates to the best way to weld the sleeve to the arm.
Seems like there are three options:
1) Should I cut a tight fit hole for the sleeve to fit through and then weld along the diameter of the sleeve with the sleeve flush with top of the arm?
or
2) Should I cut a tight fit hole for the sleeve to fit through and then weld along the diameter of the sleeve with the sleeve positioned above top of the arm?
or
3) Should I cut slightly smaller hole that will clear the balljoint and weld the sleeve to the bottom of the control arm?
Thanks
Name:	Sketch, Balljoint mod, 58 Pont lower control, v0_1.jpg
Old 06-18-2014, 11:13 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Which picture would best represent what you have?
Name:	Ball joint sleeve1.jpg
ID:	155586   Click image for larger version
Name:	Ball joint sleeve2.jpg
Old 06-18-2014, 11:14 AM
The sleeve on the right with no flange is what I have.
Old 06-18-2014, 11:40 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I put four decent sized 1/2 welds at 12,3,6,9 o'clock and haven't lost one yet. Let it cool naturally. I haven't had an issues with the ball joint not fitting or threading in. I suppose one could thread an old one in as insurance but beware the heat will have adverse effects on the socket.
Old 06-18-2014, 11:52 AM
Thanks.
How do you position the sleeve in the arm. (See my original question)
Old 06-18-2014, 01:52 PM
Banned
Screw in lower ball joint? [Archive] - Team Camaro Tech
The Following User Says Thank You to killeratrod For This Useful Post:
Mutt's37Buick (06-18-2014)
Ball joint size Mutt's37Buick Suspension - Brakes - Steering 4 05-08-2013 03:09 AM
s10 ball joint/ 4runner ball joint stevetankl Suspension - Brakes - Steering 1 06-16-2012 01:59 AM
4X4 Ball Joint Adjusting Sleeve PancakesandSausage Suspension - Brakes - Steering 0 05-01-2011 02:31 PM
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 01:39 AM
ball joint question RustBucketChevy Suspension - Brakes - Steering 4 11-06-2003 09:13 PM
