New Hobart MIG welder Century dual feed welder |
As far as I am concerned nobody makes a welder besides MILLER. I work in the erection business and that is all we use is MILLER, and you can't beat them. I have used the other brands like Lincoln and Hobart, and the Hobart would be my second choice. Lincoln dresses there welders up pretty good putty nascar logos and auto sets and crap like that on them but all that is no good without performance. I have a millermatic 135, it is a 110 MIG welder that accepts gas of flux core and is good for what you are talking about. I wouldn't suggest it for highway use but I used this welder to weld snowplow brackets on my yard truck and also used it to build a dove tail on my car hauler. But for the price that they are now brand new you are better off going with a 220 power supply and making it more worth the money. I would choose a miller or Hobart if you want it to work for ever.
I have a Lincoln 220 MIG,That is one very good machine..
I had people that wanted to give me their 110 unit's,I told them to keep it.. I wouldn't waste my money on a 110 welder.There is a big difference.You will have better heat control with the 220 unit. |
I have been using a 110 mig for a number of years now and I find for most things automotive one of those is just fine..I originally bought mine for maintenance work so I did not have to drag around the generator and trailer every time I needed to weld something in the field..I do concur on the Miller as my old Lincoln was getting tired so it was replaced with a Miller 140 with the auto set..Still getting used to the autoset feature but then I do not have to use it as the welder can be set manually as well..
Soo bottom line is that I would reccommend one of the 110 units for the guy who needs an occasional machine.. Sam
Three years ago I picked up a Lincoln 215 that was on sale with a good discount at my local welding supply. I also have used a Miller 212 as well and in IMHO both of these welders 230 V welders are the right size for automotive garage work.
With .035 wire it has the power to get excellent penetration when welding frames. With .023 wire they can be turned down low enough to handle 22 ga sheet metal. Oh, and both can use a spool gun for welding aluminium with decent results. I believe Hobart has a 230 welder similar to the Miller which offers good value as well. Nothing beats knowing what you are doing and having good welding technique, but... a quality machine will help you get the best results. Oh, and I would recommend using C25 gas over CO2 as it gives much cleaner welds. |
I recently purchased a new welder. I read every thing I could find posted on HR.com, Lincoln, Miller and Hobart web sites before making my choice. I looked at Esaab and talked with a local welding repair shop owner that I respect his unbiased honesty. He had some interesting comments, particularly about TWI now owning Lincoln, Miller and Hobart and which machines that come in for repair the most frequently. He started me looking at Thermal Arc and after doing the research and side by side comparisons, I now have a Thermal Arc 251 Fabricator. I have never welded with any thing like it and will never have to purchase another one. You can quick change the polarity: you can have two different gases on board and you can have the regular gun and a spool gun installed at the same time and switch from one to the other with a flip of a switch and turning on the corresponding gas.
Trees |
I like the small miller and Lincon 220 V machines for the price. I have a 135 miller that is 110 V that works good for small stuff and tacking header tubes together but I have a bigger 220 V 200 amp machine for bigger jobs. If I had to have one I would pick one of the 175 amp 220V name brand machines for the money and if you ever need to sell it you can get most of your money back.
Miller and Hobart are both good but Lincoln is in no way inferior and IMHO they build one of the best machines on the market. Of the "big three brands" 110 machines, all of which are somewhat limited no matter what brand, the Lincoln is probably the best choice. My current Lincoln is a Kholer (gasoline) powered 20 HP 225 AMP that I have owned for about 10 years now and just like the big diesel units that served me so well for over 35 years this one has never let me down. My little Lincoln 110 volt MIG has been going for nearly 15 years now and was simply abused for most of that time, just like the others it was always there when I needed it. The 110 volt machine was used for very small jobs in "out-of-the-way" places that were impractical to reach with the big machines and so it spent a lot of it's time bouncing around the tool box on my service truck. This thing has been used in snow, rain, mud and dust been dropped, run laying on it's side and generally had far more asked from it than it was ever meant to do. It has just about all the paint beaten off of it and is almost comical to look at now but the darn thing STILL runs just fine!! IMO those little Lincolns are DARN good machines!
I like the red boxes too. If for no other reason than they're made here in Uh-Hiyuh. (Cleveland, Ohio)
I visit a local exhaust shop whose owner cusses his new Lincoln 140C... Switched back to his used up SP-135. Dunno why. The 140C is fine by me. I could see having a 110 machine for exhaust. The size of the stinger on the big machines would get bulky. Although you can get smaller stingers (guns) for the bigger machines. Or adapt a 100L like I did. The choice was easy for me. Spent years in a fab shop running a Lincoln 255 with a magnum 250L stinger. One gets used to the feel and angle of the trigger. Miller is just uncomfortable to me. Dials are wobbly, small parts storage and ease of access is a pain. Currently have a 140C and a 255XT in the shop. Although the 140C is going bye bye. If you foresee yourself doing chassis fab or any kind of structure steel, DO NOT expect a 110 machine to do the job. Duty cycle rares it's ugly head and usually if you are not welding sheetmetal, the voltage dial is always maxed. Just seems to end up that way. Last edited by C-10; 06-11-2009 at 11:10 PM. |
| Recent Garage - Tools posts with photos |
| New Hobart MIG welder | Chris Kemp | Garage - Tools | 1 | 04-08-2009 12:36 AM |
| Welder problem - I think | Ripped | Body - Exterior | 18 | 02-11-2007 08:41 AM |
| Anyone Welder shopping? | Bruckmans Auto | Garage - Tools | 7 | 07-06-2006 02:01 PM |
| My first post and a welder question | Bugs | Garage - Tools | 17 | 11-08-2005 02:49 AM |
| Arc welder ~VS~ Mig Welder | ChrisMiddleron | Electrical | 15 | 07-08-2003 07:31 AM |
