Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Better 60' times
Old 03-23-2006, 07:37 AM
oldsmo oldsmo is offline
Redman Racing
how about you tell us what car you are working on? - 85 Olds Cutlass. 307 pulled and 350 with AFR195, ex284 and the rest of the goods no power adders.(front sits a couple inches high since I have removed alot of weight) I would say I am in or over the 400hp mark.
leaf springs or coils on the rear make for different things to change or alter to help traction. - Rear suspension is redone with moog replacement springs,boxed lower control arms,tubular upper control arms, new axle housing bushings, 3 way adjustable shocks. Everything polyurethane even the coil spring isolators, stock rear sway bar. Front sway bar removed. Battery in trunk passenger side. Just check out the Photo album.
Gear ratio , tranny , converter stall? , manual tranny? 3.73, 2004r, 3,000 stall.
I was wondering if anyone had experience with the above tire I mentioned??
I know that if I really wanted to put the power down I need race springs all around and a pair of slicks. just haven't got there yet.
