Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Better 60' times
Old 03-24-2006, 06:41 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
90/10's or even 70/30's will definitely help you out, have you checked to see if there are more body parts made out of fiberglass, I know I could get both bumpers, hood, front fenders, and trunk lid, for my Malibu if I wanted to go that route.
The reason I mentioned the air bag is if you have much chassis twist when taking off the line, about the only you can determine this is to have someone take a video of your car and look at it closely for front rise, rear drop, and twist, which will cause the right rear to drop more than the left even with the sway bar (which actually helps with this too).
